throttle support rod on transmission leaking
It looks like I am getting gear oil around the rod where it screws into the transmission. Or maybe I just spilled gear oil on it when I changed the fluid. Does this rod actually make a seal or is it a blind hole?
Old 03-09-2024, 02:08 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
It's a blind hole.
1986 Targa Guards Red
2021 MT09 SP
Old 03-09-2024, 02:20 PM
Titanium User
Doesn’t look oily to me - looks like cosmoline.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 03-09-2024, 03:31 PM
Thanks, I must have fill it with gear oil. It isnt a lot, just moist when I put my finger right where it enters the trans.
Old 03-09-2024, 04:36 PM
It's drilled through and can leak. Seal the threads with pipe sealant.
Old 03-09-2024, 10:21 PM
Well, we have one vote blind and one through hole. G50 trans. I think its drilled through as the oil is fresh. Will check it out today and confirm.
Old 03-10-2024, 05:29 AM
Is it worth looking at PET to see if it shows anything either way.
Old 03-10-2024, 08:36 AM
Tried, and it doesnt show any kind of seal or description.
If it is all the way through then I will have to let out some gear oil as its below the filler. Seems weird to make it all the way into the trans.
No big deal easy enough to get to it.
Old 03-10-2024, 10:15 AM
Well, I can confirm it is a through hole. I removed it, drained out close to a qt, put some sealant on the threads (Permatex high temp thread sealant) and put it back together. I also topped off the gearbox with oil.
Old 03-10-2024, 11:33 AM
Well I'll be, looks like my advice was wrong. I've had the throttle shaft out on my 915 a number of times and have not seen a trace of oil so I assumed (always bad) the hole was blind. I have never put any sealant on the threads and never has it weeped even a little. Guess I am lucky.
2021 MT09 SP
Old 03-10-2024, 03:32 PM
May be sealed on a 915. Maybe they opened it up on the G50 to save weight
Old 03-10-2024, 03:44 PM
It's a blind hole on the 915, I've read before it's through on the G50 but no personal experience.
1982 911SC
Old 03-11-2024, 07:11 AM
Yeah, I need to pay more attention to the pics, it's clearly not a 915 so a G50 it is. My apologies for the wrong direction.
2021 MT09 SP
Old 03-11-2024, 08:17 AM
