-   -   TDC on crank pulley does not align to TDC mark on distributor - 3.2 Carrera (http://forums.pelicanparts.com/porsche-911-technical-forum/1155801-tdc-crank-pulley-does-not-align-tdc-mark-distributor-3-2-carrera.html)
ErrorMargin 02-04-2024 04:16 PM
Continuing my project to strip my 3.2 engine down to a long block, I rotated the crank pulley to the TDC mark and noted that distributor is not quite to the TDC mark. It needs to rotate a few more degrees.
Is this normal? The engine was running very well before I started the tear down.
Is this bad?
Is the distributor installed 1 gear tooth off?
Should I remove the distributor and get it aligned dead on the marks?
http://forums.pelicanparts.com/uploa...1707091997.jpg
john walker's workshop 02-04-2024 04:27 PM
It's fine, carry on.
GG Allin 02-04-2024 06:40 PM
Having recently reinstalled my own distributor, and getting lined up perfectly, I find myself questioning this now. Being off by one tooth on my own looked similar the picture above.
john walker's workshop 02-04-2024 07:51 PM
One tooth either way would make a lot more difference than that. Carrera distributor bodies don't turn to adjust timing like SCs and earlier. You plug it in and you get what's pictured. The mechanical advance adjusts the rotor tip a bit as the rpm changes to keep it in phase.
Jeff Alton 02-08-2024 07:23 PM
What John said, that is aligned......
Cheers
