Heater ductwork
What am I missing?
On the left there is that ductwork piece the comes off fan housing and directs air to the heat exchanger. What does that on the right? There is the shroud that directs air through the oil cooler. But what takes the air to the exhaust heat box?
You are missing a "hot air socket" 911 106 327 00
Look under that shelf one more time, it's got to be here somewhere |
Uncertifiable!!!
BTW, I would plug all those holes into the heads and block with take of rags before you inadvertently drop a nut or washer into one of them.
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Thanks. It is empty. I just put it together hollow if you will to fit it up in the car. The transmission is heavy enough. I wanted to mock it up to see where I have room to put stuff.
One generally learns this the hard way
