I am wondering how to install longer wheel studs for wheel spacers. After removing a rear wheel and the brake rotor, I thought I could just push the wheel studs out of the hub and push in the new longer ones from behind. But there is not enough room to do this because the parking brake assembly is in the way. It looks like the wheel hub needs to come off. Bentley seems to be saying (420-19) that the only way to remove the rear wheel hub is to first remove the axle and push out the hub from the inside "using Porsche special tool P297." Oh great, is there not an easier way? Do I need a special tool to drive out the wheel hub.?
Front looks easier, as it appears that that the hub and rotor come off together (Bentley 401-13).
John C 1988 911 Carrera coupe 2002 BMW 530 Last edited by Decolliber; 05-25-2004 at 08:07 PM.. |
Friend of Warren
It is doable. John Walker described it in a thread. A search should bring it up.
Kurt V No more Porsches, but a revolving number of motorcycles. |
The 914 article is the closest thing to the job you are talking about, if the Carrera is pretty much the same. The biggest difference is the E-brake. JW uses 2 pry bars and some courage on the hub flange. Once you get the hub out, make sure you get the studs in straight. The lug nuts themselves will pull them home, but if they aren't good, you can't get the wheel on without marring up the holes. This is where a steel wheel and steel lug nuts are useful.
I would take the hubs, front and back to a machine shop and have them press them in. I used a friend's press and it went well. No banging or weirdness. |
John C 1988 911 Carrera coupe 2002 BMW 530 |
Is this the thread you mean Kurt?
Replacing Wheel Studs I think I understand now. Hammer out old studs and pass new studs through e-brake cable hole from the inside. I still worry about damaging the hub by hammering on it though.
I removed my the halfshafts and tapped the hubs out with a large socket and a dead blow hammer, then used a press to push the studs in and out. If you don't have a press you can use a piece of pipe to catch the studs and a large vise. Or take the hubs to a garage, many of them have presses.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
But if you tap the hubs out, don't you have to replace the bearings?
I did this summer 2003 with advice from Rennlist. You do not need to remove the hub. Once the rotor and caliper are off you can remove the e-brake adjuster OR the e-brake cable. Hammering out the old studs does not take too many blows and pulling the new ones thru with steel lugs is pretty easy. IIRC I used 76mm studs which are kind of big (OE is 45mm?) and I could only just get them thru from the back. The studs I have would allow the use of a 25-30mm spacer. The moral being, choose your stud length carefully and get the smallest ones you need for the intended spacer otherwise you will find it difficult to fit.
While you are in there, remove the stone gurds (aka brake heaters) for slightly cooler brakes (if you have not already done so). Richard |
Friend of Warren
Senior Member
Yep, removing the hub destroys the bearing, or at least it's supposed to. And yes, you can change studs without removing it.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I don't like hammering out the studs due to the force it puts on the bearing. Use an air hammer / air chisel and some penetrating oil.
You can also loosen them up by heating the hub around the stud with a propane torch. I find you can install up to 76mm studs (good for 28mm spacers) using the ebrake cable hole. But I don't think you can do 100mm studs (for 2 inch spacers) this way.
Chuck Moreland - elephantracing.com - vonnen.com |
Well, the BFH technique (KurtV and JW) works, but it took me the whole day just to do the back wheels. Hammering out the old studs and putting in the new ones was the easy part. Pulling out the e-brake cable and putting it all back together was what took so much time. In order to get enough space to insert the new studs I had to remove the e-brake cable and the two folding braces, and putting it back together was what was really hard. Like a Porsche version of a Rubic's cube. I ended up having to completely dismantle the e-brake system, springs, pads and all. Had to experiment with different sequences for putting it all back together.
By the end of tomorrow I should have my new RUF wheels on (purchased from Lindy). If I had known what a headache it would be getting those studs in I might have had second thoughts.
I'm in the middle of installing longer wheel studs and just completed the rear which I thought would be the hard part.
Is there any way to install longer wheel studs in the front without disassembling the wheel hub? |
Registered Minimalist
Dang 20 year bump. Might be a new record for Pelican. :-)
You have to take the hub off. It's easy though. Take the caliper loose but keep it conntected to the flex hydrualic line so you don't have to rebleed the brakes. Carefully tap the grease cover off with a 1X3 and a small sledge. Angle the 1X3 under the lip by resting it against the hub and rotate and tap. Remove the spindle lock thing (forgot the name) and big washer, slide the hub off, separate the rotor from the hub. Use a press to remove the studs (don't hammer them out, you'll damage the aluminum hub. ) Take this opportunity to at least re grease the front bearings, if not replace them completely. Follow the proper torque procedures and reassembly instructions to ensure you can move the washer slightly with a screwdriver when you put the threaded nut thingy back on. :-)
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
I figured I better search before posting a new thread
![]() Taking the hub off wasn't too bad after reading the instructions. |
