Can I have heat with a 12 plug dizzy
Are there heating ducts available for 12 plug?
Old 02-09-2024, 09:53 AM
Been here a while
yes, search for "heat backdate".
I have a twin plug distributor on my '72 - like yours, I used a 930 duct to solve the clearance problem. The oil line for the Carrera tensioners can also present a bit of a problem, but also can be modified to make work.
looking for 1972 911t motor XR584, S/N 6121622
Old 02-09-2024, 10:34 AM
Yes, but I made my duct myself, so that may not be the best option for you.
1976 914
1986 951
Old 02-09-2024, 10:52 AM
"930-106-321-01-PH? That part gets terrible reviews for a poor fit"
is this true? part doesn't fit well
also the only pictures I see with a twin plug dizzy is the distributor with the two small caps I think 964? the belt drive for the second cap and rotor.
the relief in the duct looks big like it may clear the fatter single cap twin plug diz.
and those parts look like the are tin. not plastic?
thanks
Old 02-09-2024, 03:40 PM
Old Codger
Toddrivers's Avatar
IDK if this was an original 930 piece or fabbed up by the PO but here are a couple of pics from when I had it off, and yes the heat works fine with the right duct in place.
Old 02-10-2024, 02:27 AM
Yep that’s the ducting piece I saw. I read fit was not really good but I don’t know. I would to get one of those from pelican but the are $119 not terrible but if it won’t work with twin plug distributors then I’m kinda stuck with it
Do you know if it will work with the 12 plug dizzy it’s pretty wide When looking at it installed it is very close to cylinders
Old 02-10-2024, 11:10 AM
PCA Member since 1988
I doin't know how much wider the 12-plug distributor is than the regular SC distributor. I had to modify the duct with a few whacks from a ball-peen hammer to give a few mm of extra space for one of the plug wire towers. I would think you could to the same with a little more sincerity to clearance the 12-plug distributor cap. If you heat it up to dark red with a propane torch it will be much easier to work.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-11-2024, 12:11 AM
