-   -   Combo Gauge Install (http://forums.pelicanparts.com/porsche-911-technical-forum/1156753-combo-gauge-install.html)
margabuck 02-11-2024 05:14 AM
Combo Gauge Install
http://forums.pelicanparts.com/uploa...1707660063.JPG
68 911T Targa that I bought in pieces. I didn't take it apart so sometimes I have questions on how it goes back together.
The large 100m combo gauge doesn't have the posts and bracket(s) like the other 4 gauges. So I'm not exactly sure how it was installed. None of my gauges had the rubber seals...those had been removed at disassembly I suppose.
Do I use the gasket that also doubles as the mount? PN 91164190200. It seems to have been used on gauges in 1970+
https://www.pelicanparts.com/More_Info/91164190200
puppynuts 02-11-2024 06:41 AM
I drilled and tapped two holes, then glued two long screws in and cut the heads off.
