woodruff key and shims 10p15c a/c compressor
Rebuilding my 10p15c a/c compressor. My disassembly put the shaft woodruff
key and shim at the top of the shaft in a 'safe' place. So safe that I cannot find it (call me an idiot). The woodruff key has the pn of f11-5120 in the santech catalog. Anyone who can source either of these items would be greatly appreciated. Thanks, dgc2 javascript:winopen('upload.html') |
Seriously though - woodruff keys are usually readily available in "standard" sizes at your local hardware store.
Thanks for the info. Yes I found the original in Germany. It's rectangular shape is not
found in the Woodruff selections at the local sources. More searching. |
If you click the second link you can see various straight keys in both SAE and mm sizes. They have under and oversizes. They also sell stock to machine your own. The rounded type keys are in the third link. I think those are like the ones you need.
https://www.mcmaster.com/products/keys/key-type~straight/ https://www.mcmaster.com/products/keys/key-type~straight/machine-keys-5/ https://www.mcmaster.com/products/machine-keys/rounded-machine-keys/ |
I just checked my old 10P15C parts. The size for woodruff key is 4mm x 4mm x12mm in length (rounded on one side).
key is same size on most 10P15, E and C
If you get stuck, grab one that is larger at parts store and gind it to size, with slight chamfer on edges. |
| All times are GMT -8. The time now is 10:47 AM. |
