fallingat120mph's Avatar
Verifying fit of washer hose and clamp recommendations..86' Coupe.
Ordering new lines/hoses and nozzles. Previous owner deleted all lines...
Want to make sure the 4x6mm are correct from users.
https://www.pelicanparts.com/More_Info/PCG02030110.htm?pn=PCG-020-301-10-OEM&fc=Y
I will be ordering the above but wondering what everyone is using for clamps or would a snug clean zip tie work? Trying to avoid leaking especially after I put all this back together.
Everything is in great working order (including the "intensive washer") - pulled all
reservoirs and cleaned, all pumps checked out so good to go.
Thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 02-22-2024, 02:42 PM
That's fond- just deglaze
Hi Erik- I used #99951252700 clamps when I replaced all the check valves in Petra's system. They are described as "Clamp - Hose Spring - 8.5-10.5mm". I'm not sure if a zip tie would offer good clamping pressure. I used Oetiker Clamp Pliers to tighten the clamps.
As an aside, here's my story on the mold in the tank, which got me started down the road to replace the check valves...
https://forums.pelicanparts.com/porsche-911-technical-forum/987971-weak-washer-system-solved-mold.html
Missed Approach
Petra- 1986 Coupe
Old 02-22-2024, 05:30 PM
Originally Posted by Missed Approach View Post
Hi Erik- I used #99951252700 when I replaced all the check valves in Petra's system. It's described as "Clamp - Hose Spring - 8.5-10.5mm". I'm not sure if a zip tie would offer good clamping pressure. (They can be had for as little as $3-$4 per unit)
As an aside, here's my story on the mold in the tank...
Fantastic.
...and what a great write up. I searched and searched and how I missed your thread is beyond me.
Really appreciate it and will add to my cart here on Pelican.
Again, thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 02-22-2024, 05:33 PM
Hi Erik- I used #99951252700 clamps when I replaced all the check valves in Petra's system. They are described as "Clamp - Hose Spring - 8.5-10.5mm". I'm not sure if a zip tie would offer good clamping pressure. (They can be had for as little as $3-$4 per unit) I used Oetiker Clamp Pliers to tighten the clamps.
Of course since I am impatient these might work?
https://www.harborfreight.com/assorted-single-ear-hose-clamp-set-40-piece-58463.html?utm_source=google&utm_medium=cpc&utm_campaign=12169520316&campaignid=12169520316&utm_content=140182169715&adsetid=140182169715&product=58463&store=3431&gad_source=1&gclid=CjwKCAiA_tuuBhAUEiwAvxkgTgMlqGm_3AMEu1mWCo59 uNf2pPPbUzwVUSK5mv1CSDF27HX0KTjzghoCfw0QAvD_BwE
1986 911 Coupe
1986 911 Targa
Old 02-22-2024, 05:43 PM
Hi Erik- the 8.8-10.5mm pieces in that pack certainly look like they would fit.
Missed Approach
Petra- 1986 Coupe
Old 02-22-2024, 06:22 PM
The lines to the check valves are friction fit, as I recall when I pulled mine (1977) to replace the gunked up ones and the flexible hoses, there was a small rubber sleeve covering all the connection points including on the washer pump itself, helped maintain tension instead of a tiny metal clamp.
Product called Gates (heat) Shrink Clamp is a sufficient replacement for the oem.
Old 02-23-2024, 01:40 PM
EC900 is correct for a non-intensive washer system. I'm assuming the higher pressures dictated the use of clamps for 1986. The clamps are noted as Part #6. Mine were a bit torn up after removal, so replaced with new ones. Here's the 1986 schematic...
Missed Approach
Petra- 1986 Coupe
Old 02-23-2024, 01:56 PM
Thank you both for the input. The schematic was a bonus and really appreciate.
Yes, having the "intensive" system has been quite eye opening! Thought I could clean and be back to business.......not so much. Again, thank you both!
Erik
1986 911 Coupe
1986 911 Targa
Old 02-23-2024, 02:20 PM
