Alternator wire rubber boot
Hi,
Does anyone know where I can purchase the electrical wire rubber boots that go on the alternator terminals? Mine have deteriorated and would like to find a replacement. Thanks |
If I recall, a smaller distributor cap 90 degree rubber boot will work well, unless you can locate the "factory" part in the Pelican catalog. It proves the old adage, "never throw anything away."
cycling has-been
I found what I needed for the alternatorr terminals at Aircraft Spruce.
Terminal Nipples from Aircraft Spruce Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Bill,
What size did you order? Also, were you able to fit these over the existing wire connectors, or did you have to cutoff and install new terminals? Thanks, David
__________________ David Yerkes 1987 911 Targa - GP White |
cycling has-been
Being rubber, these stretch over the terminals - with a little Vaseline and gentle persuasion. Bill K
You can get something close from VW online store Wolfgang International. I found an alt/gen rubber boot, item 113971 for $3.95 a piece.
69 911T 2.4S |
Assuming you disconnected the battery while working at the back of the alternator when would the boot be needed? Maybe if the ground wire came loose and swung over to the hot lead, that's about all I can think of.
Sold: 1989 3.2 coupe, 112k miles |
To keep dirt and grime out.. possibly minimize corrosion. Agree that a boot is probably not needed.
2024 update since I was looking for this very thing…you want a Bosch alternator wire boot https://www.***************/pn/3130558000. (********nz, sorry pelican, couldn’t find it in you catalog)
![]() (New and old from my 1970 911) B |
