Electrical gremlin
Advice needed! My '81 930 has some symptoms and I hope you can help me in the right direction. Car is 100% original.
Symptoms: - right front indicator not working (fuse keeps blowing out) - fresh air blower stopped working - with the lights on, I cannot turn the car off; lights out, engine stops right away - dash light speedo very dim (all other clocks are good). All lights from all clocks were replaced 1,5 year ago. - the small green light in the top of the speedo flickers when driving off (faster and faster and then stays on) - speedo not showing the right speed (less than actual speed) What did I do so far - Replaced the alternator. Did not have any effect - Just ordered a new speed sensor (attaches to transmission). I think I damaged the current one when installing the engine last year. - I did replace the light switch last year. Any correlation? Any help is appreciated!
----------------------------------- 1971 911 T Targa 1980 930 Turbo 2017 991.2 4S Targa 2023 Cayenne |
Engine won't turn off with lights on. I had this problem and believe it or not it was caused by the wrong bulb in a taillight. A single filament bulb where there should have been a dual filament. No clue as to your other gremlins, good luck.
Fresh air blower
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
