-   -   How to question (http://forums.pelicanparts.com/porsche-911-technical-forum/115798-how-question.html)
72 four door 06-21-2003 06:44 AM
How to question
I own a 72T and its a royal pain to start. I have to prime the stacks in order to start her. Me and my windex bottle filled w/fuel aint cuttin it. So i need to know how to wire a priming button on the dash and what wire to hook it too . I know the thing on top of the fuel filter/has to be wired. If any one can help man id be grateful.
bell 06-21-2003 08:53 AM
is your fuel pump coming on during cranking?
you shouldn't have to do that.......and fuel will eventually eat through the windex bottle and make a mess :)
72 four door 06-21-2003 01:19 PM
Yes it is coming on once the car starts she starts and runs ok its not a windex plastic bottle its an old glass bottle.
bell 06-21-2003 01:25 PM
i'm not real familiar with early carbed cars but if the pump isn't coming on while cranking and only only comes on after the engine starts then it sounds like possibly a power supply problem.....maybe ignition switch, someone else will chime in i'm sure.
p.s......i re-read your post.....needed a comma i think :D
does it only happen when the engine is cold? or sits for long periods of time?
jim72911t 06-21-2003 01:36 PM
From your description of the fuel filter, it sounds like your car still has the original MFI. This system has a fuel enrichment circuit built in; note the little "T" fittings on the side of the stacks. Have you checked to see if it is working properly?
If you don't already have a copy of "Check, Measure, Adjust," I'd suggest downloading a copy. I believe it can be found somewhere on this site; do a search. The MFI system seems a little daunting at first, but once you get to know it a little, is straightforward to troubleshoot.
Good Luck,
Jim
'72T
72 four door 06-21-2003 02:17 PM
i do have mfi and the fittings are good theres just no fuel coming from them
