AzioAceAzio's Avatar
Noob advice on worn throttle shafts remedy
Outside of a rebuild or replace has anyone found any success in remedying worn throttle shafts? I think it's causing some major vacuum leaks but I'm admittedly still learning how these work. '76 2.7 with weber IDTP crabs.
Old 02-28-2024, 02:52 PM
Administrator
Matt at Pelican Parts's Avatar
Hi AzioAceAzio,
Can you give a little more detail on what's going on? I tried to do some searching on the topic and found an older thread that might be of interest. Post #2 mentions worth throttle shaft bushings a a possible culprit and offers a few suggestions
https://forums.pelicanparts.com/porsche-911-technical-forum/581193-weber-crisis-faith.html
Old 02-28-2024, 06:12 PM
Nope, if shafts are leaking you’ll need to pull carbs, dismantle, measure and replace worn parts, shafts/teflon bushing/ et.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 02-29-2024, 06:41 AM
Thanks all for the advice thus far. Minor update and I wanted to get some feedback. The car generally runs and drives fine, maybe some slight stutter but I chocked that up to cold weather and carbs. Something interesting today though: at idle, the with the car up to temperature, if I were to floor the gas as if to rev as quickly as possible, the car starves and quickly dies. It will restart just fine. I did this 3-4 times consecutively, started to smell fuel so I stopped. Possibly my accelerator pump? Replace the diaphragm? Thoughts?
Old 03-02-2024, 05:25 PM
lateapex911's Avatar
Certainly while looking into the throttle bodies when opening (by hand) the throttle you should see a accel pump squirt of fuel. (Be careful, a backfire while doing this could...at best...singe your eyebrows, or much worse)
The timing and amount are key to crisp throttle response.
On the throttle shafts, a good way to tell if they are influencing the car is to spray some starting fluid at them. If the engine surges, it's an indication that they are leaking.
Might be all 6 or a few. If there is no change in the idle of the car when spraying it on, that's an indication that they are tight.
Disclaimer: I've dorked with the Webers on my 911 to get it running better, then sold them so I'm no expert. There is a book "The Weber Tech Manual" by Bob Tomlinson out there. I'd be happy to sell you my copy if you'd like the deep dive info.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 03-03-2024, 01:55 PM
