2,7 liter 1976
2 electrical wires
anyone knows what those 2 might be?
One is green ,the other grey sort of greybrown both with little spade connector hanging loose under the car just in front of the rear wheels.The wires are going up the trans and then.....
1988 Carrera
Jimmy
Please include model year of your car.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Didn't you have another thread about a rat's nest of wiring left by the previous owner? Those terminals aren't factory so it's anyone's guess.
1982 911SC |
Is that where the reverse switch is on the 915? It's on the RH side of the G50.
Nope, 915 is on the tail and is a pair of bullet connectors, not spades. Maybe someone cut in a junction on the wires? Who knows with this car from the other thread I saw.
1982 911SC |
Been here a while
In that area, there are 2 pairs of wires standard, 1 pair is for the electrical pickup of the speedometer sensor. The other is the backup light switch.
obviously, the wiring has been adjusted by a previous owner. but it should be easy to see if the speedo or the backup light switch has no wires going to it/them
looking for 1972 911t motor XR584, S/N 6121622 |
2,7 liter 1976
ok ,thanks a lot . I will check those 2 options.
I’m with blue, speedo wires. Connection is thru a boot into the rear shift cover area. No need to cut wires, just disconnect at 2 poll connector and push connector with boot out the back of tunnel. Now u need to repair wiring. Im guessing your speedo didn’t work.
PCA Member since 1988
Grey/brown is the back up lights. The wire to the switch should be green/yellow.
See if your backup lights are working.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
2,7 liter 1976
at the moment nothing is working,even no battery installed. a bit difficult to check things.
getting the wires / cis functional. here and there loose ends(all sorts of) thanks for the answers good chance it s the speedo |
