Can anyone tell me which part of the door handle assembly I broke?
The door opens fine from inside. It won't open from the exterior. The handle required quite a bit of force for a while and finally it stopped working altogether. I'd rather just have the part ordered before I disassemble everything.
https://www.youtube.com/shorts/z_oboeSi_lg |
to be quite honest, it is hard to say if anything is broken.It could be just the bolt loose which hold the little finger ...It is actually not that hard on your model to remove the door panel and remove the handle ,Once is out i`d bet you`ll see the problem ..
Ivan |
Some of those outside handles have a finger that needs to be positioned between a "V" on the inner mechanism. If that finger is outside the "V," outside handle does not open the door. (Not sure if that's the finger Ivan is referring to.)
http://forums.pelicanparts.com/uploa...1709498282.jpg
So big surprise, the trigger failed. What is the proper solution? Just buy another handle? I see there are a few other trigger solutions but a search on Pelican says they don't fit or work well. |
One more question - Does anyone have the Rennline drilled door handles?
I think they look slick but it says I need to swap the door lock mechanism from an earlier car. Is this necessary? |
Well, what I see is the dove tail joint isn’t seated. The 5mm stud with the hex at the bottom is what secures that. Take a deep 8mm socket and try tightening the stud/bolt to reseat the trigger pin housing with the dovetail.
The finger is broken,here is one for you on ebay.com from CA no.131232780510..ops i see now it is from renn.
here is one complete...375184131586 Ivan |
i think if you would get the whole handle ,you would just have to replace the tumbler,it will work,,I just the finger from renn..i do not know..i`d get the handle if it was me
Ivan |
I have bought repro triggers in the past & used them successfully.
Ivan |
I bought that used one from eBay as it appears to be easier to swap tumblers and reinstall than it is to swap triggers, I think. I still may order the snazzy Rennline drilled handles but I need to figure out if I need to swap the lock assembly, which I really don't want to do. |
Unscrew the stud/bolt, take it apart, let’s see what’s broken.
Ivan |
Of course, I dropped one of the mounting nuts into the nether region and have to hit the hardware store for a new one.
Ivan |
I had the chrome drivers handle break years back on my '73. I bought the TMP from Pelican, and it was poorly made.
I was fortunate that I was able to use parts from the TMP and the original to get it in good shape, but would not purchase it again if I had it to do over. |
The swap went flawlessly. I apologize if I missed this in my Pelican search but on the Early 911 registry, I found a trick to swap the tumbler and I figured I'd post for anyone else who has the same problem.
Insert the key in the old tumbler, remove the flathead on the lock mechanism, leave key inserted until you insert it into the "new" handle, then you'll have a functioning key without having to set the tumbler or visit a locksmith. Takes about a minute to complete. |
| All times are GMT -8. The time now is 11:32 AM. |
