911 3.2 SSI Heat backdate w/AC
Hi looking to backdate the heat in my 3.2 which is currently running SSI with no heater hoses hooked up.
Looking at the Pelican site it looks like I will need to modify this part in order for me to keep the AC
https://www.pelicanparts.com/More_Info/91110632201PH.htm?pn=911-106-322-01-PH&SVSVSI=911M&DID=25663
Does anyone have any advice or pictures of what needs to be modified?
Also for the hosing can someone provide a link for the proper hose? I will need to replace all of it so it might be better to buy it in bulk vs the individual pieces on pelican.
Thank you
Old 04-14-2020, 12:13 PM
To modify the part you have to reposition the elbow lower on the plate. Where it is as shipped it will interfere with the AC bracket. I had a welder cut and re-weld. Hard to believe no one makes one that fits properly, but I could not find one.
For the hose, I used 60mm black aluminum. You can find it on Amazon pretty cheap. Just measure for total length.
https://www.amazon.com/Hvlystory-Heater-Ducting-Webasto-Dometic/dp/B07NPHGJFV/ref=sr_1_17?dchild=1&keywords=60mm+heater+hose&qid=1586921443&sr=8-17
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 04-14-2020, 08:03 PM
Thanks that is what I was thinking but didn't know if it would require more then that to make it fit. I might just ended up modifying the stock one then if it will require cutting and rewelding anyways.
For the engine Tin did you cut holes in the existing Tin for the Heater hose to pass through or did you buy the earlier style tin with the shorter side and the square hose path throughs?
Old 04-15-2020, 06:39 AM
I actually did both; I have an '87, but it is heavily modified (turbo, etc.). I used an older set for the passenger side (two pieces, one small one with the hole), and drilled a hole in the stock driver side.
'07 Boxter
Old 04-15-2020, 08:53 AM
Use turbo parts and SC parts, all readily available
The left through the tin by the chain box is a pre 75 piece
Bruce
Old 04-15-2020, 09:04 AM
Bruce
I'm backdating heat on an '87 as well. Would you be able to break down what parts are needed?
Old 04-15-2020, 10:00 AM
Look on the PET, pages 105-05 and 105-10.
The air channels and right and left (4pieces total) sides that bolt to motor
Turbo air channel has a cutout for distributor room
The right two pieces are the same from 75 to 83
The left long piece is standard over years
The left short piece with the 60mm hole was up through 74 and 76/77 with thermal reactors
Bruce
Old 04-15-2020, 12:52 PM
Bruce
Thank you.
Old 04-15-2020, 01:58 PM
fred cook's Avatar
1980 SC heat backdate
When I built the 3.3SS engine for my 1980 SC, I did the heat backdate and kept the a/c like you are wanting to do. I think I was able to flatten the "pipe", actually made it kind of oval enough for the a/c brackets to fit over it. Just make sure to put the hose and clamp on before installing the a/c mounts.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-15-2020, 03:52 PM
Below is a list of parts I used:
930.106.321.02 Left Hot Air Duct (930 version for better distributor clearance)
911.106.327.00 Right Hot Air Duct
911.106.331.00 Right Hot Air Duct Support
911.106.036.00 Right Hot Air Duct Cover Plate
911.106.827.00 Right Hot Air Duct Closing Plate
901.106.825.00 Left Tin for Hot Air Hose
901.106.826.00 Right Tin for Hot Air Hose
911.106.083.01 Left Tin
901.106.084.00 Right Tin
901.106.085.05 Front Tin without Hole (No longer available from Porsche)
Good luck!
Old 04-15-2020, 04:55 PM
Right Side Heater Duct for AC Cars
Thank you
You will be better off using the factory version of the Right Hot Air Duct because you have AC.
It is made up of the following (4) parts:
This is what it looks like assembled:
Old 04-15-2020, 05:18 PM
Sorry to piggyback on this thread, but I have the four pieces assembled for right duct. Planning to do the backdate when I do plugs and wires in the near future. Any difficult attaching the “support” part with engine in place? It looks like this attaches to underside of engine shroud, correct?
Old 04-15-2020, 05:47 PM
Thank you for the tips and tricks, going to start planning out the project this weekend. I guess that is the good thing about being stuck at home more time to work on the Porsche
Old 04-16-2020, 06:31 AM
Jezabel, Canada has both side pieces you need and the through holes. For sale page 1
Bruce
Old 04-18-2020, 09:07 AM
Wer bremst verliert
JohnJL's Avatar
Bruce
Good luck!
THis thread is gold but would be helpful for some of your pictures of the modifications/final assembly? Please?
Thanks!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-04-2024, 05:39 AM
