-   -   front parking lights not working any more (http://forums.pelicanparts.com/porsche-911-technical-forum/1158241-front-parking-lights-not-working-any-more.html)
francesconyc 03-02-2024 11:17 AM
this is about my 911 SC 1982
so my front-passenger-side parking orange light was working
front-driver-side not working
today I noticed both are not working
I replaced the front-driver-side BULB but still not working (I got the bulb from AutoZone, I hope is correct)
is it possible that I messed up something with my headlights as I recently replaced the bulbs?)
Fuse box is ok, the rear parking lights work as they should, so it can't be a fuse
any recommendation welcome!!
Francesco
HarryD 03-02-2024 11:22 AM
Check that the current bulbs are good using an ohmmeter.
Check for voltage at the bulb socket with a multimeter or test light.
Are the front and rear bulbs on the same fuse?
EC900 03-02-2024 06:30 PM
Check the ground wiring (brown) might be corroded in/at the housings, maybe knocked the wire.
I don't have an ‘82 diagram where the side lamps body ground point is but mine is on front left side.
francesconyc 03-04-2024 06:22 AM
thanks all!
so after few tests, it seems a ground wiring problem
also ironically, I tried to pull the cable form the back and magically the bulb started working again..
at least I discovered it is a wiring problem nothing major...
