Ignition
I'm looking for ways to ignite a carbureted 3.2 motor on an older car.
Thank you. |
PCA Member since 1988
Too little information.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Registered Minimalist
Yeah need more info, but If I'm picking up what you are laying down, the easiest is an MSD 6AL box, with a nice set of Clewitt wires. Buy the MSD coil and viola, ignition. Plugs on carbs like to be a little hotter with a bigger gap fyi.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Administrator
There's also folks running Megasquirt, Haltech, AEM, and other EFI computers configured only to control spark and remain carbureted. Not the simplest option of course but it has been done a few times
IMO the "ignition 123" distributors are an interesting option. You can adjust your timing to best suit your engine and combine them with almost any ignition system from stock CDI to MSD. Just be sure you order the correct version for your purpose.
Regards, Guenter 73.5 911T, mod |
Yes if your distributor needs a rebuild anyway, like mine did . . I went with the 123 ignition distributor and it works great . . is also eliminates the need for a CDI so I bypassed the questionable one in my 1972 911 MFI.
Thank you everyone for the responses. Sorry I didn't give enough information. I have an MSD box and I wonder what I can use for a trigger without using the motronic. The car is a 1974 and the motor is a 1984.
The 84 3.2 Carrera had a dumb distributor. No advance or trigger mechanicals. It just has a rotor do direct the spark. The ignition advance and trigger is performed by the DME using the sensor that read the flywheel teeth (see picture).
![]() You will need to replace both trigger and advance functions. This is where the 123 distributor suggestion comes in. The 123 distributor would replace your dumb distributor with a distributor that could trigger your MSD and provide ignition advance. Other options listed are to use some type of programable system to replicate the DME ignition function. Clewett has a solutions that replace the whole distributor as well. https://www.clewett.com/index.php?main_page=index&cPath=1_71 lots of different ways to go. John |
Dave |
Thanks again. I think 123 is my best option since I have everything else.
Have you verified that the 123 is compatible with a 911 3.2 engine, i.e. CW rotor rotation?
Dave |
Let me make sure: You are NOT running the Motronic system on your 3.2 engine, correct? If so, then the 123 is the best option. It is available with the correct gear for the distributor rotation on SC and Carrera engines
If you are not using the Motronic, what is your induction system?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-10-2024 at 06:34 PM.. |
The only option, i.e. given no tach output on the SC 123, is to convert the a low signal SC/3.2 tach to a coil signal tach.
Dave |
I verified the 123 distributor for SC/Carerra engines with Ian Carpenter. In fact, I'm ordering one myself.
Tach signal: It depends on whether you use a CDI box. The CDI boxes and MSD generate a tach signal. If you go straight from the 123 dizzy output to the coil, I don't know. There are adaptors for tach signals. To get the correct answer, contact Ian Carpenter, "icarp" here. He's tech support for 123 Ignition. The link to the 123 distributor site: https://123ignitionusa.com/porsche-3-0-or-3-3-sc-911-or-930-up-to-89-bluetooth-no-hkz/
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-11-2024 at 12:29 AM.. |
i.e. an inductive discharge 123 ignition produces a better spark. Semiconductor technology for ignition systems has improved significantly since the 1970s with CDIs. It's unfortunate that the 123 doesn't provide a tach output. It would be a simple add-on to the original 123 design.
Dave Last edited by mysocal911; 03-11-2024 at 04:40 PM.. |
| Tags |
| carburator , carburetor , carburetors , help for a conversion , question |
