Door speakers for 911 SC
Anyone have experience with good speakers for the factory holes in the front doors of a SC. Hole measures 5.5 inches. Must be flush so factory door panel and grill will remain as is. TIA
Old 03-03-2024, 09:23 AM
I'm good with tools.
AG81's Avatar
Rick,
I just used the Focal PC130 in my 72.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 03-03-2024, 10:47 AM
Nice looking speakers but you have to use their grills, as the tweeter sticks out. Trying to use factory panels.
Old 03-03-2024, 10:58 AM
Been here a while
I used these on my 79, fits fine with factory door panels and factory grilles, I was able to reuse the factory water shield behind the speakers with some minor fiddling.
https://www.crutchfield.com/p_091RCX130/Focal-RCX-130.html
looking for 1972 911t motor XR584, S/N 6121622
Old 03-03-2024, 11:24 AM
Thanks for the reply, so those tweeters will fit behind stock door panel?
Old 03-03-2024, 11:46 AM
Been here a while
They do.
Old 03-03-2024, 12:51 PM
The Infinity Reference 6532ex fits flush: https://www.crutchfield.com/p_108R6532EM/Infinity-Reference-REF-6532ex.html
No need to cut the door. 6.5” fits perfectly. From my notes:
- I installed a 10” square foam sound pad behind the speaker to minimize back waves and reverb inside the door cavities, placing it about 1” from the bottom of the door so it wouldn’t soak up any water that might accrue faster than it drains.
- The existing speaker screw holes did not align with the tabs on the new speakers (not surprising; they never do), so I drilled four new holes and used new black self-tapping (#10; used a 5/32 bit for the pilot holes) screws to attach the speakers to the door. Goal was to make it look OE / not leave a mess.
- I used a set of nylon washers to better insulate the metal speaker mounts from the door from a vibration perspective when screwing them into the doors.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/
Old 03-04-2024, 10:16 AM
stevie 77 930's Avatar
Front speakers
Infinity Reference speak 6.5 in for the fronts as well. No door panel fitment issues at all
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 03-04-2024, 11:43 AM
Perhaps you want to check out parts-express.com? They have a full range of speaker that cover all sorts of applications and dimensions.
I used them in my last interior update and found the ones that were a perfect replacement. The speaker brand I bought was Wavecor.
Good luck.
Edit: I was able to reuse the stock speaker grills - a requirement you stated above.
Old 03-04-2024, 03:02 PM
Thanks guys.
Old 03-05-2024, 05:59 AM
'87 Targa
Stevie,
With the speaker mounted to the metal frame behind the door card, how do you mount the grill?
The speakers I'm familiar, the grill is kinda keyed around the perimeter of the speaker rim.
Old 03-05-2024, 07:56 AM
Originally Posted by WMichelsen View Post
Stevie,
The speaker grill is attached to the door card, the grill has 4 pins with little snap clamps on them.
1983 911SC
2018 GTS
2023 Audi A4
Old 03-05-2024, 09:02 AM
