Send a message via AIM to EPorsche
Cruise vacuum lines
Anyone have any good pics of the vacuum lines from the cruise control servo?
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 02-22-2008, 03:28 PM
Mitch Leland's Avatar
There are two, one larger diameter hose that runs across the firewall from right to left, then there is a small diameter hose about 8"-10" long that goes from the plastic "T" to the cruise control unit on the left side. I just installed my engine and couldn't figure out where the small line went, it goes forward of the big hose so when the big hose is installed you can't see the small male fitting on the cruise control unit.
I installed a new smaller hose and use a new clamp on the larger hose. The cruise control was always a little wimpy, had a hard time getting to the proper speed, then it wouldn't hold it. Now it pegs itself where you want it. Works as good as my GM car. The only problem is I have to find the switch for the brake, you have to go a long ways on the brake before the cruise control disengages. Naturally you can disengage it from the stalk on the steering column.
I can take a pix if it will help, let me know...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 02-23-2008, 08:37 PM
Do you have pics and where do the small and big lines connect to?
'81 911SC stock
Old 02-23-2008, 08:39 PM
mikeatfhc's Avatar
I'm interested in seeing a pic as well. The Bently diagram doesn't show where these two lines connect.
'78 SC Wide Body, '81 Engine. M&K 1in2 Out, Carrera Sways, ER F&R rear monoballs, ER control arm bearings, ER spring plate bearings, turbo tie-rods, ER strut brace, Tarret Drop links, Bilstein custom-valved shox, Rebel Racing bump-steer kit, 22mm F, 28mm R TBs. Rebuilt calipers, new wheel bearings.
Old 02-24-2008, 08:08 AM
robhamster's Avatar
I dont need a picture, but does anyone know where the big hose attaches to besides the cruise control servo?
1984 3.2 Cab (now toy)
1975 911S (old toy)
Mercedes E350 W4 (snow car)
2007 911 Turbo (water and air pumper)
2012 Panamera 4S (for the wife, I swear)
Old 02-24-2008, 09:19 AM
Friend of Warren
The big hose is just a vent line and hangs into the opening in the firewall between the two shock mounts.
Kurt V
Old 02-24-2008, 10:30 AM
Yes, open to the atmosphere.
Old 02-24-2008, 07:35 PM
Small Vac Line To Cc...
Howdy,
The small vacuum line comes off the white plastic "T" as shown in the picture and runs to the male fitting on the side of the cruise control module. The smaller fitting is just ahead of the larger hose connection. You can't see the smaller hose connection in the picture.
Mitch Leland
Old 02-24-2008, 08:29 PM
Cruise Control Vent Line
Is there a penetration for the vent line that just hangs open, or does it just rest inside the engine compartment?
Old 03-04-2015, 01:14 PM
universeman's Avatar
Just hangs in the engine compartment on mine
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 03-04-2015, 03:51 PM
Banned
guys, i want to remove the whole cruise control unit - but - how to get the hose from the pedal to the engine?! am i missing something?!
Old 03-10-2015, 07:13 AM
Going through lines in the engine bay ('86) in preparation for re-installing my motor and was perplexed by the big servo line going into the pinch weld opening between the shock towers, so thank you for putting my mind at ease that 1) it's open to atmosphere and 2) that it just drops into that slot. Thanks.
_____________________________________
2017 Targa 4S | 2016 Cayman GT4 Clubsport
1997 Carrera S | 1986 Carrera
2016 Cayman GT4 [sold] | 2015 Macan Turbo (sold) | 2006 Cayman S [sold]
Old 03-05-2024, 07:25 AM
