aways's Avatar
1987-1989 Carrera doors
Does anyone know if the coupe and targa doors are identical for all 1987-1989 Carreras?
Thanks in advance for any info.
commandant of the compound
Old 03-05-2024, 10:46 AM
The bare door is. Just use your coupe or targa parts in it.
206 637 4071
Old 03-05-2024, 07:36 PM
fallingat120mph's Avatar
Two 1986's here...
Am swapping out doors from a very low mileage targa to my coupe.
The low mileage targa had 1 great door and both targa doors had excellent internals.
Few things:
-Since I am swapping completely different doors I just removed from the hinge bolts and not the pins.
-Buying an 8mm 12 point driver for the B pillar adjustment made alignment so easy.
-Make sure the internals are the same, my situation was one door had central lock and the other did not. So, make sure and do your homework with that.
-AND...if you are swapping doors DO NOT forget to swap door handles/locks.
Got everything back together with one door and totally forgot to swap locks...ooof.
Again, this is from two 86's but thought these little things might help to know.
Erik
1986 911 Coupe
1986 911 Targa
Old 03-08-2024, 12:34 PM
