l_turn9's Avatar
Battery Group for 74 911?
I checked my OM but could not locate the Barrery Gr # - What works well?
Old 03-15-2024, 12:33 PM
I have a Group 48 in my 77, perfect fit with the factory hold-down.
Check the model numbers on your current battery, the group size might be encoded on the label.
For instance mine reads L3-H6-48CP
Old 03-15-2024, 01:43 PM
I believe the big version of the batteries is an H8….they are HUGE and heavy. Most of us run the H6. There should be bolt holes for both for he bracket to hold the battery in place.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-16-2024, 08:11 AM
E Sully's Avatar
Group# 42, 500 CCA
Ed
1973.5 T
Old 03-16-2024, 02:19 PM
