-   -   Why is this leaking? (http://forums.pelicanparts.com/porsche-911-technical-forum/1158967-why-leaking.html)
yelcab1 03-16-2024 09:44 AM
This is a CV boot on the gearbox side of a 356. It is leaking since it was newly replaced. Can someone enlighten me on why?
http://forums.pelicanparts.com/uploa...1710607469.jpg
john walker's workshop 03-16-2024 11:47 AM
Is the seam at 45° from vertical or vertical? Can't tell from the pic.
yelcab1 03-16-2024 12:02 PM
It's horizontal . is that the problem?
john walker's workshop 03-16-2024 01:44 PM
Could be. Some sealer at the end gaps helps, too.
proporsche 03-16-2024 02:23 PM
in the past i have experienced if it was way too tight it would leak-at the bolts and nuts...Also i would but wider clamp..is that an aftermarket rubber?
Ivan
yelcab1 03-16-2024 02:54 PM
Ivan
They don't have original rubber anymore.
T6andT 03-16-2024 03:17 PM
Been there, John’s advise is spot on, mine still would weep on the wheel side. Ended up sanding a smooth section on the tube and sealing. Sorry do not remember the sealant I used but no leaks since.
