911SC '82
Im installing missing seals on my sunroof lif and body
Does anyone know the correct direction? Vertical? The bump is up or down?
If thats the glue in part, felt side up and towards the sunroof. Did mine years ago, will have to do it again soon. If i rememember correctly i used a bunch of masking tape.
This may help -- lots of photos
https://forums.pelicanparts.com/porsche-911-technical-forum/376404-sunroof-cable-repair-new-seals-87-911-a.html |
@Francesco
Find all infos you need here: https://nineelevenheaven.wordpress.com/renew-sunroof-seals-on-911/
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
911SC '82
911SC '82
thanks!!!! |
