Bahama yellow
Has anyone here looked up a current paint mix for bahama yellow used from 1967 to 1969? Number 6605, code 110.
Thanks in advance |
(man/dude)
I bought a small amount to spray out as a test - the formula is below. In the pic, the fender is Bahama Yellow, and the Decklid is Signal Yellow.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Available in Glasurit as well. 22, 55, and 90 lines.
I like them both. But like the Bahama yellow just a little more than the other.
Bahama yellow is the bomb.
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
(man/dude)
Of course it's a matter of taste, but I was considering the Bahama yellow for the previous project (hence the test fender) but I found it to be a bit drab in person, especially in comparison to the bright and cheery presence Signal Yellow on the decklid.
The Carbon Copy will be Signal Yellow.
I'm good with tools.
I went that way too Jonny. My current endeavor.
![]() It's no where near being finish but I have it this far..... The motor has to come back out tomorrow.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Thanks again for your answers
