Help removing SC seats
So i had a 3.2 carrera at one point and easily removed the seats with an allen wrench.
Now, i have a 81’ 911sc, and cant find the bit to get to the 2 bolts(per each side) and and remove them. Its a very tight fit, cant get anything that fits between the rails with a ratchet Did anyone have this issue? Willing to buy the correct attachment with ratchet to make my life easier
Thin Wall 10-mm Socket………
Use a thin Wall 10-mm socket to remove the 2 bolts on the seat rail. Or ground the wall of the socket to fit. The one I have is from Craftsman Tool Set.
Tony |
Thanks tony
Fb = M/S
This is what I used to get to those two nuts with a thin wall socket:
https://www.amazon.com/gp/product/B07M5BJZY1/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 The low profile wrench worked great - my seat blocked the upper portion of the nut head, and I also had Craftsman sockets which fit.
1981 911SC, Guards Red/Black Leather 2014 Audi A6 Prestige, Phantom Black Pearl/Black Leather, Black Optics 2017 Tesla Model X Gone but not forgotten: 1969 Datsun 2000, 1973 914 1.7, 1976 912E Last edited by aoncurly; 03-20-2024 at 07:10 PM.. |
I tried a 3/8th craftman socket and it was too thick to get in between the rails
I will definitely buy this wrench, just need a thin wall socket for it
https://www.amazon.com/gp/aw/d/B079NKGQ26/ref=ox_sc_act_title_delete_1?smid=A1THAZDOWP300U&psc=1
Hopefully the combination with the low profile wrench will do it Last edited by lada03; 03-20-2024 at 07:56 PM.. |
10-mm Thin Wall Socket………
Use 1/4” drive 10-mm thin wall socket (Craftsman) or other brand. The 3/8” drive 10-mm thin wall socket will not work because it is too big unless you grind it down to fit.
Tony |
Grind down a socket to fit ....
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
(man/dude)
Snap-on 1/4" drive should fit, they don't get much thinner than that...
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Heck, I’m only 5 not 71!
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Use The Appropriate Tools…….
These are what you need to remove the SC seats from the rails. Use the shorter socket for the rear bolts.
![]() Tony Last edited by boyt911sc; 03-21-2024 at 07:11 AM.. |
Thanks everyone
I ordered the low profile wrench and thin wall 10mm 1/4 drive craftsman |
Replace the bolts with socket head cap screws of a suitable grade when you put the seats back in - you'll find it easier to remove them again in the future if you need to.
'80 SC Targa Avondale, Chicago, IL |
10mm probably around 18ftlbs not sure just guessing.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Bolts upgrade
Well, i got the right tools and 10min job, I love this forum. What a wealth of knowledge, thsnk you all
![]() I went though my parts stash and found 10mm allen wrench bolts They look a bit shorter than the SC bolts. I have 6, short a few… maybe someone has a couple? Also found a couple with a cut. Which ones are correct? In the picture, the oem SC bolts have the washers ![]()
I swapped my SC to allen heads after the first time I struggled to get a 10mm in there...
It makes seat removal a breeze, which in turn makes other repairs easier.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
Belmetric, McMaster-Carr, or your local hardware store will have what you need.
Buy the right grade. I'd buy 10.9 or higher as I see no reason not to. |
