What were the fuel pressure values of the old FPR with and without vacuum? How about the new FPR? Thanks. Tony |
Since the injectors were sent out and "cleaned", you really don't know the real state of the injectors, e.g. are they even the correct ones. Hopefully, they are the low impedance (1-2 ohms) injectors. Obviously, the wrong injectors will cause problems like you're having. Have you measured the temp sensor at the DME ECM connector, i.e. pins 13 & 5? |
Yep, I checked those before as you instructed. Pin 5 was properly grounded. Port 13 read 1.67v I bought it from reputable users on these forums. I have no reason to believe they are anything but reconditioned OEM injectors. |
Did they supply the ECM? If not where did it come from? Quote:
I can check the warm output for the CHT sensor, but I really don’t think it’s that as my issue is primarily with the cold start. To try and be more specific. The problem seems to be that the car starts and can’t “catch” the idle as it drops down. So it immediately dies. Occasionally it gets close, and will fire a few extra times before dying. That would lead me to the idle switch, but I have two of them which both test fine. I did test the EMC on another car but who knows, maybe I just got lucky when plugging it in that car. I’m gonna do another vacuum test in the morning to see if that returns anything. |
I had the same issues with 85 3.2 spent a day chasing cold start and idle issues, got an innovate wide band 02 gauge and spent another day, used the 02 sensor in the bung disconnected the narrow band and tuned idle CO with AFM bypased according to bently manual, finally got CO and idle set, no vacuum leaks fixed and still had some cold start issues til i ran the heck out of it, drove like a maniac and it settled down and runs like a champ now. I dont let it set for a week and it starts and runs great. If i let it sit for 2 weeks cold start issues until i get it warmed up and run for an hour. 200K or more on the motor. Needs valve job but still CA smogs
unrelated to a rich fuel mixture. But you mentioned up-thread that it will start OK if the AFM is disconnected, which doesn't correlate with this last post. Hopefully now the thread has converged on the real basic problem, a momentary bad start-up idle! |
I want to see if I can borrow his good ECU to test on my car. |
Testing your suspicious ECU on a good car is OK, but not the other way around, as a good ECU could be damaged by a suspicious car. A shorted ICV, for instance, can kill an output transistor inside the good ECU of your friend.
1. bad idle valve (you indicated you checked it) 2. bad idle switch, connections, or not positioned correctly 3. bad idle valve drivers in the ECM You should test the idle valve using this procedure; Idle Valve Testing, post #20, http://forums.pelicanparts.com/porsche-911-technical-forum/360766-bench-testing-carrera-idle-control-valve.html Additionally as a simple test, you can open (CCW) the idle screw on the throttle body at least 8-10 turns. This should reduce or eliminate your having to press the throttle pedal. |
I reached out to the person I purchased the motor from, turns out the DME is not the one that originally came with the motor but one that had been in another car of his. So the custom chip in there wasn’t for this motor.
I’m gonna start by trying to reset the idle. I’m also going to try and source a stock chip. |
http://forums.pelicanparts.com/uploa...1714256367.jpg "Reseting the idle" is ONLY used when the idle is within 50-100 RPMs of the desired idle per the Porsche spec. It's NOT the major source of your problem. If the engine idles OK when it's warm, then idle doesn't need to be "reset". Remember, once the engine is warm, the idle valve is only used to stabilize the idle for load variations, e.g. A/C, lights, etc. It can also prevent idle undershoot on engine decel. |
Ivan here https://www.911chips.com/fuelsys.html |
If the idle valve system is functioning properly, it should have the same effect as your pressing on the throttle pedal at startup to keep the engine running. Did you do the the valve test on post #20 here? http://forums.pelicanparts.com/porsche-911-technical-forum/360766-bench-testing-carrera-idle-control-valve.html |
| All times are GMT -8. The time now is 11:02 AM. |
