86 911's Avatar
Send a message via AIM to 86 911
Euro 3.0 Pistons Passing California Smog?
I'm currently rebuilding my 1978 911 SC engine. Depending on what my machine shop tells me about the condition of my existing pistons & cylinders, I may want to upgrade my pistons to the higher compression Mahle Euro 9.8:1 piston. I was told that the higher compression will make the engine run a little hotter and increase the NOx.
Is anyone here running Euro 9.8:1 pistons in California? If so, have you had any issues passing smog? I've searched but have only seen 10+ year old threads. Interested to see if there are more recent experiences.
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 03-25-2024, 05:54 PM
I have a set of the Euro 9.8:1 pistons and cylinders available for sale. The cylinders have been honed and are ready to be installed. I was going to use the set on my SC engine rebuild but decided to go a different direction.
I can't comment on passing CA emissions.
Old 03-25-2024, 06:52 PM
86 911's Avatar
PM sent!
Old 03-26-2024, 05:28 AM
PCA Member since 1988
The increased CR should not affect your emissions significantly. What are your current smog test results?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-26-2024, 02:01 PM
AndrewCologne's Avatar
Hotter engine running does not affect NOx in a way not passing smog test.
What lets NOx rise is a too lean mixture. So you just should set the CO correctly, thats it.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 03-26-2024, 02:11 PM
86 911's Avatar
I pulled my previous results and they were well below half of the max. allowable values. Thanks for easing my nerves if I go this route.
Matt
'71 VW Bus
Old 03-27-2024, 09:55 AM
