911SC '82
Ungo Box Alarm Removal
Despite many threads on this every case is different so see if I can find a way to remove mine
What I did so far:
- I removed the siren (it was next to the spare tire)
- I was able to locate wiring in the smuggler box going to my box installed in the glove box
- I removed the flasher switch, and the fuse connectors (the red light is still on in the Box tho)
- by mistake, I cut a wire that is #1 or #4 and the car was starting so I connected it back, so I'm gonna keep it that way for now.
so to my understanding, it seems that the ignition wires have been routed to the Ungo Box and form the Ungo box back to the ignition. I think I can safely cut all the other wires because they don't affect the car, but I need to find WHERE the ignition wires have been re-routed.
is this something done under that dash usually?
Cna also someone tell what the heck are the other wires for "Instant ON" "Radio sense" ??
Old 05-04-2024, 06:43 AM
When i removed the alarm on 85 the installers interrupted the yellow wire under drivers side of dash.
Old 05-04-2024, 10:13 AM
proporsche's Avatar
frances...dude..try to make your pictures smaller so some not skilled peeps actually can see the whole pic
Just modify it in paint
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-04-2024, 10:53 AM
Just remove any non-stock wires and repair any separated/cut connections back to stock.
206 637 4071
Old 05-04-2024, 11:58 AM
911SC '82
ok, i was able to remove it!!!
the main two ignition wires (I guess SEND & RETURN) where white wires connected to some purple wires probably coming from the fuse box, I guess interrupting the fuel pump maybe
I imagined that connecting purple to purple would create that bridge and I was lucky it was it.
I then proceeded to remove everything else.
along the way, I'm afraid I have cut a couple of black/ground wires thinking they were belonging to the UNGO. but everything electrical seems to work fine
what's not working now is the headlight sprays (but I couldn't care less) and the clock stayed behind (it was working before) so I guess I juse need to ground them again
Old 05-04-2024, 02:50 PM
Ground is brown.
206 637 4071
Old 05-04-2024, 10:23 PM
911SC '82
usually yes in europe, but i guess some black wires for the alarm were U so that re black and they were connected to the body
Old 05-05-2024, 06:19 PM
proporsche's Avatar
brown is world-wide always brown....just little info;-)
Ivan
Old 05-05-2024, 11:41 PM
PCA Member since 1988
Nope. Not on some Japanese motorcycle brands. BTDT.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-06-2024, 01:08 AM
proporsche's Avatar
Ok thanx for the info.., i thought we are talking Porsche 911..;-)..not house electrics or moto?
Ivan
Old 05-06-2024, 02:30 AM
