patalive's Avatar
Door Striker Mechanism Woe?
I have an irratating problem with the driver's door on my 93 C2.
When I shut the door after getting in the car, using the inside door handle, it does not stay fully latched. It is only "half latched", meaning I can wiggle the door - If I roll down the window, reopen the door and then apply firm, downward pressure on the external door handle as I reclose it, the door stays fully latched. (NOTE: it is not a "sealed car" problem - this occurs even when the windows are down) - When I leave the car, I have to shut the door, again with firm pressure, on door handle area in order for it to stay fully latched.
Is this a striker problem, or something loose inside the door latching machasism? Any other thoughts?
Thanks for your help!
Chuck
93 C2
Old 06-22-2003, 09:02 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Sounds like the striker needs to be adjusted up just a touch. I would remove the striker and check the alignment of the door in the closed position. If your satisfied with the fit then re-install the striker and adjust untill smooth operation is achieved.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 06-22-2003, 09:45 AM
