Marshal voltage regulator question
Hi guys,
I'm having problems with my (original to the car) external Marshal SEV voltage regulator. The correct replacement part seems to be Part#: 911-603-901-00-M262 Am I correct in thinking that: the blue wire goes to 3 the brown wire to 2 the black wire to 1 Many thanks, David http://forums.pelicanparts.com/uploa...1711380437.jpg http://forums.pelicanparts.com/uploa...1711380542.jpg |
Yes I think you are correct.
Ground (brown) is definitely the middle terminal (2). Black goes to terminal labelled "Field" (FLD) (1). Might be labelled DF. Blue goes to the remaining terminal (3). It may be labelled D+. |
Thanks Wazzz!
| All times are GMT -8. The time now is 12:24 PM. |
