SFR SFR is online now
911 SC Coupe/Targa door glass difference
Couldn’t find this in search…is there a difference in the door window glass for Targa and Coupe?
Old 03-25-2024, 06:21 AM
Yes. Coupe has more curve at the top.
206 637 4071
Old 03-25-2024, 06:41 AM
Interesting, is there a way to tell or is it subtle?
Is this one Coupe or Targa?
Old 03-25-2024, 06:49 AM
PCA Member since 1988
If you look at the two windows side by side it is obvious. If you are not familiar, then it's not so obvious. the Targa window is almost straight on the top edge. I don't know about the numbers--try typing them into Google with "Porsche" and you should get some hits.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-25-2024, 02:33 PM
Mark Salvetti's Avatar
These two classified ads show the difference pretty clearly.
Coupe Door Glass
Targa Door Glass
Mark
1979 911SC Targa
Old 03-25-2024, 06:10 PM
In addition to the profile of the top of the glass, the profile of the rear edge is slightly different, too. It’s a bit more vertical on the Targa. The two parts shown in the links above do a good job of showing the difference.
'80 SC Targa
Avondale, Chicago, IL
Old 03-25-2024, 07:00 PM
Thanks Mark - the pictures are super helpful.
Old 03-26-2024, 07:45 AM
