It took only 49 years!
CDI dead
I recently got a new battery and Daisy would not start. We did a phone/video diagnosis with Jamie Pertuit (Tuit Tech); checked that the carbs are getting fuel, and looked at other stuff,. Jamie asked if the CDI was whining; it wasn't.
It seems that after 52 years, it has gone kaput. What is the general consensus here on the board regarding CDI repair versus new CDI, new CDI with more advanced electronics in them? If repair is the way, which is the better place, ECUDoctor, Ashlock, any others? For new, Parts Klassik, Ashlock, any others? Any help is much appreciated...I NEED to drive Miss Daisy!
Serge: In the heart of Philly! Daisy - 1972 911T 2.7L Light Yellow Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD ![]() Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
May be send it to Dave/Loren (systemsc.com)?
Gilles RoW 88 Carrera coupé |
Been here a while
I would only go to Ashlock.
looking for 1972 911t motor XR584, S/N 6121622 |
Really! You know how to properly evaluate CDI rebuilding services? Please explain.
Dave |
Titanium User
I've had great experiences with Bob Ashlock.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Found this;
Dave |
I have had ashlock repair 2 of mine. Stellar service, good guy. I even sent him back one that I thought still had an issue. It ended up being the green wire. He runs them through a hot box test to ensure even the hottest climates and conditions will not kill it. Lastly, he has his own version of the CDI if you wanted an upgraded version. I simply went with stock refurbishment.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Been here a while
“If repair is the way, which is the better place, ECUDoctor, Ashlock, any others? For new, Parts Klassik, Ashlock, any others?”
Ass-engine Nazi slot car -- PJ O'Rourke |
They are on Porsche's recommended suppliers list. They first designed a CDI in 1968 for 1967 Porsche 912. They provide a 5+ year warranty.
Dave |
Ashlock repaired my CDI last June. Has worked perfectly since and looks pristine. Recommended.
If you want to learn about cdi's...
https://forums.pelicanparts.com/porsche-911-technical-forum/226517-history-bosch-cdi-toubleshooting-info-parts-list-changes-schematics.html
72 911 Although it is done at the moment, it will never be finished. |
+1 for Bob Ashlock.. He's been doing my CD boxes for more than 10 years! He's the best!
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
All explained in those posts by the original Pelican Parts CDI supplier.
Dave |
Bob Ashlock. Done a couple for me. Came back looking new and working same.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Still here
Buy the new fangled CDI unit, some of which may have shiny lights and other fancy features included, probably get those quicker too saving the roundtrip, and send the old to the rebuild vendor of your choice, I have no skin in the game, my guess being they are all equally good for most intents and purposes, speed might be the deciding factor given your urgent need to DRIVE MISS DAISY, you can even open up the busted unit and have a look see, post pics if you do ... we love pics, prior if you're into that stuff. If you do get the new unit, report back as well ! |
PCA Member since 1988
Another option: If you have to spend several hundred dollars to fix or replace your CDI box, consider spending $900 to get a whole new 123 distributor (you can set customized timing curves) with new epoxy ignition coil. It's a much better way to set optimal timing for your engine, and you can ditch the olde CDI box, and points-based distributor. Several folks here have them and swear by them. I just recently ordered one, but it hasn't arrived yet.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
If you need one quick and it is a 6pin, you can barrow mine until you get a new one/rebuild yours. Also, if it is a 6 pin you can get up and running super quick with a MSD 5520 for around $200.
Been here a while
If you need a quick one and it’s a 3 pin, I have a spare in NJ. If you need a 6pin, I have a spare in SoCal that can run as a 3 or 6 pin
Both recently refurbished by Bob Ashlock.
