-   -   Trans output flange question (http://forums.pelicanparts.com/porsche-911-technical-forum/1159579-trans-output-flange-question.html)
inaminit 03-29-2024 07:52 AM
We have a trans with 110 mm fine spline flanges-would like to change to 100 mm. What is the best way to do this?
Matt Monson 03-29-2024 08:33 AM
Buy a couple of SC flanges, sell your 110mm ones.
Step 3: profit
spuggy 03-29-2024 09:16 AM
What Matt says - quite rare, and many turbo or 930 transplant guys with a 915 would take your arm off at the shoulder for a chance at those. Maybe the 3.6 transplant guys as well.
Or just remove the hub stub axles and use 3.2 G50 axles if your power output makes that worthwhile or you get tired of backed-off/broken M8 bolts.
gled49 03-29-2024 09:50 AM
76-77 Turbo had 2 different 110mm drive flanges. Open diff flanges are short and have limited application. LSD flanges are interchangeable in most fine spline diffs. By 78 fine spline drive flanges we’re the same length, just 100 & 110mm fitment.
stownsen914 03-29-2024 09:59 AM
Coarse spline or fine spline? Advice is similar either way, only difference is where you get the 100 mm ones from. SC / early 3.2 Carrera for fine, mid 70s 911 for coarse.
inaminit 03-29-2024 01:52 PM
Thanks all for the education. The trans is a later lsd unit, so it makes sense that it would be a fine spline. So I need 2 fine spline 100 mm flanges. Should I specify length on my WTB?
inaminit 03-29-2024 05:02 PM
And a final question: what would be a fair pelican to pelican price for the 110/fine flanges?
inaminit 03-31-2024 05:27 AM
Bump up
would like to know a fair Pelican to Pelican sell price for a pair of 110 mm fine spline flanges
Matt Monson 03-31-2024 06:09 AM
California Motorsports sell new ones for $1100. A decent price for pair of used ones is $700-800.
If you’re still looking for a pair of 100mm, I might have some. I’d want $250 shipped for a pair.
inaminit 03-31-2024 06:29 AM
Thank you Matt-please let me know if you do have a set of 100 mm
