Odyssey pc925 battery
After 2 years battery died. Had battery checked and will not hold a charge. Battery was maintained with Battery Tender Jr. All winter long. Went to take car for a drive on this nice sunny day and no go. Dead battery. Read online not to use Battery Tender on Odyssey batteries. Battery was never disconnected from car. Read that wouldn't be a problem. Anyone else have problems with Odyssey battery PC925
Ive had that battery since 2015, car does not get a ton of use and sits on a tender in the garage. I took the car out last Friday for the first time this season marking 9 years since I installed.
1982 911 Targa, 3.0L ROW with Webers |
I'm good with tools.
My first PC925 died at 3 years almost to the day. I kept it on a tender recommended by several folks familiar with that particular battery. I then met a rep for Odyssey at SEMA. I told him what had happened. He suggested that I not keep it on a constant tender. Charge it, then unplug it. Then check it once a month. Plug it in for a day then unplug it. I was at 6 years on that battery when I sold the car. I now have twin PC925 batteries in my 72 and charge them on and off as described above.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Mine hasn’t died yet, but it definitely does not hold a charge more than 2 nights if it’s not on the tender. Would love to hear about any other lightweight batteries people have used that last longer.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Kind of Blue
I've had mine for almost 3 years and never had an issue. I've never placed it on a tender as I am very lazy.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Does the battery tender JR have an AGM setting? AGM batteries require a different charging profile than standard lead acid batteries -- see, e.g. https://www.interstatebatteries.com/blog/how-to-charge-an-agm-battery -- I use a CTEK 7002 (with the agm setting turned on) with my agm batteries, but don't leave it plugged in 24/7. I only top them off with it if/when they've been sitting undriven for over a month. My 911's last AGM battery lasted over 8 years this way.
I bought the NOCO Genius 5 charger today. Going to see if repair mode will revive the battery
I had them installed on my Boxster Spyder and my first one died at 2.5 years and the second one wasn’t holding a charge for more than a couple of days so I had to put it on a tender immediately otherwise it would die. A good charger can bring them back. I sent an email to Odyssey inquiring about a possible warranty situation and their response was that it is not designed to be used on street cars which includes my Spyder and the 964.
I recently transferred it to the 964 and installed a Braille in the Spyder and so far that seems to be ok after 3.5 years of use but overall I’m not impressed and not sure I’ll buy another.
CURRENT: 2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black 1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue 2024 Macan White, Beige / 2010 Cayenne White, Black PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey |
After putting charger on repair mode at 600pm yesterday and at 400am this morning checking on status it was done and in standby mode. I then switched to 12V AGM mode. After 12 hours battery was at 12.3 Volts at 600pm. I then switched it again to repair mode. Seems to be coming back. I will check again tomorrow.
I have the same battery in my car. I was warned by one of the gurus of this hobby, to never let an Odessey battery go dead. He said they’re OK if they never get rundown, but if they run down, they don’t come back very well.
Mark 1987 3.2 "Nancy's ride" ('cause Nancy owned it for 27 years before me) 1984 3.5 “Charley” (Charles owned it for 27 years) |
Up date on revival of ODYSSEY PC925. seems to be charging battery now. At 75% to 100% now. Green light pulse. Hopefully full solid by tomorrow.
I’ve had really good luck using CTEK chargers on my batteries, most have lasted 7-8yrs. I just installed a pc925 in my car last year so I have a while to figure out.
If you haven’t checked, Odyssey has a recommended method on their site. https://www.odysseybattery.com/wp-content/uploads/sites/2/2020/05/ODYSSEY_Battery_Reconditioning_Charge_Procedure.pd f CTopher Last edited by Ctopher; 04-21-2024 at 01:54 PM.. |
I just replaced an Odyssey PC925 that lasted 14 years and 2 cars. I was pretty pleased. I always kept it on a trickle charger when parked.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
Was your battery cables connected to battery?
If I'm being asked there was only 2 years when the battery was out of the car. I stored my car for 2 years when I was stationed in Hawaii. The rest of the time (12 years) the battery cables were connected to the battery.
911slant -- battery drain from being connected to car shouldn't be an issue (especially with a trickle charger that's designed to maintain an AGM battery) IF the car's electrical system is otherwise healthy -- i.e. doesn't have a parasitic drain.
My '86 had just such a drain for a while (a failed driver's door switch left the relay that keeps the power window circuit alive until the door's open energized indefinitely, causing my normal sized battery to completely drain within a week). Some smart chargers will interpret a parasitic drain as a defective battery and refuse to charge the battery at all. |
Sad news today. NOCO GENIUS 5 charger says battery is bad. Battery would not charge fully. When disconnected battery charger battery would drop volts to 3.85 volts and has stayed there for 2 days now. I believe I need to buy a new battery.
I had 2 of these batteries. First one lasted 6 years, so I bought another one. July 2023 after $325 it lasted 3 months. Had it on a glass mat trickle charger and would only hold 7.5 volts. Amazon refunded me the money. Went to Walmart and bought a 325 amp lead acid one for $79 and it works perfectly. At that price I can buy 3 of them for the cost of the Odyssey .
Did the Walmart battery fit into your Rennline holder?
I’m also curious if the Walmart battery was a lighter weight battery or standard.
