993 hydraulic lifter issue
How do you remove the hydraulic lifter on a 993 rocker? Just pull it out? Also, are the rockers supposed to look different, flat on one and a raised portion on the one in the foreground?
Old 03-31-2024, 07:29 AM
One is intake, one is exhaust. Best not to mix up rockers. If the lifters don’t fall out they can be pulled out.
Old 03-31-2024, 09:10 AM
thanks. I bought the rockers already removed from the engine, so I dont know that the lifters are bad, but easier to replace now than later.
Old 03-31-2024, 11:42 AM
