-   -   Running Temps?? (http://forums.pelicanparts.com/porsche-911-technical-forum/115975-running-temps.html)
s-man 06-22-2003 02:54 PM
Running Temps??
Hot day, so is the guage...Highway cruise heres the stats, need advisement.
Highway cruise-80mph
Ambient Temp- 84.2 F
Humidity- 35%
1973 911S Mfi-
Experiencing a reading of 230f in these conditions, wanting to learn if this is acceptable or if this requires an investigation.
Thanks....
Joe Bob 06-22-2003 03:02 PM
That's a "little" high but not unreasonable. Is the timing set right? Had it on an exhaust analyzer lately? A lean condition will cause it to run warm.
s-man 06-22-2003 04:31 PM
The car itself is running well, have my own gunson and have tested with it to get it to run well throughout the range.
I am wondering if maybe my plug selection is the culprit?
Not sure what I have in right now, but really shouldn't play a role in oil temps.
Lean, probably not, runs too well and as we all know with MFi's running well is more a likely hood of rich than lean.
Well, will wait for additional advise, it was a hot day, maybe I have a gauge or sending unit issue rather than other adjustment issues, worth a look into.
Thanks!!
Joe Bob 06-22-2003 04:32 PM
You could confirm oil temps with a pyrometer. See if the gauge and sender are accurate.....
s-man 06-22-2003 04:37 PM
Where could I get a meter as suggested for a reasonable price?? and where would I be pointing towards in order not to get a conflicted reading from within the engine by area.
Could also be the fact that I have no aux oil cooler in this car. Most S's would, but this edition doesn't.
I was baffled, but seeing that this was a Canadian delivery car, or maybe it was an option, who know's, but there is none....
michigan 06-23-2003 03:52 AM
I recently bought a pyrometer at radio shack of all places. Cost was 50 dollars. Works good. Trying it out on all kinds of things.
