HELP: car sat for 2 years it won’t start
Hello everyone,
My car sat at a body shop for 2 tears. I tried to start it today but it won’t start. Is there any trick I could do? I feel like it is not getting gas. There is no place to spray fuel into it like a carburetor
I tried to search this forum but I was not sure what the key words were to get a hit.
Please help me to get it start.
Old 04-07-2024, 09:45 PM
Let’s start with the basics:
1. What year is the car?
2. Was it running well when parked?
3. How regularly was it driven before it was parked?
4. What have you done to try to start the car? New battery? Drain tank and put in fresh fuel?
5. Does the car crank when you try to start it?
6. Does it turn over at all? Any signs of almost starting?
Old 04-07-2024, 10:13 PM
You have to give us more info. There's more to it
than just turning the key. Especially when it sat for
2 years.
Bill Douglas's Avatar
An easy first try might be to spray a whole lot of this stuff on the aircleaner filter. It would be good to see if it sort of fires up so you know the spark side of it is OK. Two years isn't long so tere shouldn't be fuel issues.
I know New Zealand has slightly different fuel to you guys. Ours is from Singapore. But my spare engine had say for about 8 years and sprung into life as soon as it was put into my SC.
Old 04-07-2024, 10:42 PM
Sorry I realized I forgot to tell you about the car: 81 911 sc euro. Sorry
Old 04-07-2024, 11:15 PM
The car ran fine before I took it to the body shop and it has not yet run since then.
Yes turning the key, it cranked for a while. Battery seems good still. I have yet to check for spark. Is it just a matter of take out a plug and place it on the head, crank and see if it has any spark? I did put in gas treatment about 5 months back. I will check spark first. If that is good then I will empty the tank and put in fresh gas.
Old 04-07-2024, 11:21 PM
@Bill Douglas: just take out the air filter and spray that stuff onto the air box? Is that what you meant? Thanks
Old 04-07-2024, 11:23 PM
PCA Member since 1988
You can spray it two ways:
1. spray for about three seconds into the intake horn on the air cleaner.
2. If you have the air filter off, lift the air metering plate and squirt about 2 seconds up into the rubber boot.
If it fires, you have spark, so no need to remove a spark plug. Then focus on fuel delivery.
Next, if it sat for two years, how did you maintain the battery during that time? Make sure the battery can crank the engine easily.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-07-2024, 11:32 PM
Schulisco's Avatar
Start here:
https://cis911primer.com/pages/test_troubleshoot.html
There's also a troubleshooting guide:
https://cis911primer.com/Troubleshooting%20Guide/Notebook%20Spiral.html
This CIS Primer for the 911 is the primarily source to get a first overview and a basic understanding of what you urgently need when troubleshooting a CIS car...especially a lambda controlled CIS like yours is supposed to be.
Saw that your car is an euro equipped car. So here the CIS is quite a bit simpler than the lambda controlled US SCs (less sensors).
Further questions:
* how old is the fuel? Probably elder than the 2 years? 3years and older todays fuel is almost no more ignitable
* rust within the gas tank? This pollutes abd damages the fuel pump for sure (and probably more from the CIS)
It would make sense when you put a video online to let us easier help you as some things can be easier diagnosed when seeing and hearing what the engine makes or not ...
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 04-08-2024, 12:25 AM
Fires up prior to sitting in the shop, if it was mechanically sound
I would suspect you need new battery. Even tho you're getting
12.6v but the cranking Amps is what you need to turn the engine.
Bat acid might a dried up. Barrow a good bat and crank it up.
Good luck.
Old 04-08-2024, 10:27 AM
theiceman's Avatar
if the battery has enough power to turn it over it has enough to start it
Id make sure the air plate isnt stuck before spraying crap in there. CIS cars do not like that stuff and it could backfire and blow your box.
1. with no ignition on take out the air filter and gently lift the air plate, the plunger in the FD could be stuck and this would free it up.
2. turn ignition on make sure you hear the whine from the CDi ignition ( it its factory ) .
3. if good, again lift the sensor plate briefly , you should hear the fuel pump run and the injectors spraying ( do this briefly as those injectors are spraying. )
4. if you don't hear anything make sure your fuel pump relay hasn't become dislodged.
5. if you hear them spraying , try to fire it up.
incidentally i parked my SC for 4 years once, fired right up .
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-08-2024, 10:55 AM
Thanks everyone for your advice. I will try those suggestions and hopefully it fires up.
Old 04-08-2024, 10:55 PM
