G50 bell housing
I have an issue with the engine mounted oil cooler hitting the bell housing of the G50 trans
my engine is built from a 3.0L case I have a BEHR engine mount oil cooler that I got from a dealer it says the cooler fits up to 89 so it fits a G50
oil cooler on the trans won't go trans on the cooler won't go
is there an engine mount cooler that is just for the 87-89 cars?
Old 04-07-2024, 06:38 PM
All the same. Picture would help.
206 637 4071
Old 04-07-2024, 07:20 PM
Here is a pic The bell housing will not let the cooler go on
Old 04-07-2024, 09:44 PM
The cooler looks like a replacement, it should fit. I’ve found some replacement parts that have fitment problems.
Old 04-08-2024, 08:55 AM
Cooler looks like a replacement to me too
Try getting an original to try I have one you could try but its in CT
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 04-09-2024, 08:05 AM
Engine Oil Cooler………
That is not the OEM engine oil cooler for your ‘89 Carrera 3.2 motor. You got the wrong cooler from your dealer.
Tony
Old 04-09-2024, 08:46 AM
If they list a cooler for a 72-89. How could it not be for an 89? My engine case is an 83. I did think it was BEHR. But it just says made in Germany and has Porsche number on it.
Old 04-09-2024, 09:36 AM
GG Allin's Avatar
It looks like you could carefully and safely grind away on the area between the flange and the welds to make it work.
Or maybe not. Not sure if oil passes through that part, or if it's just some sort of solid spacer.
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 04-09-2024, 09:52 AM
