911SC '82
URGENT How do i unscrew this from fuel filter??
Im not sure which direction does it unscrew the pipe ftom the bottom of fuel filter… i was able yo remove accumulator and filter but this is puzzling
Where the wrench goes?
Old 04-06-2024, 10:29 AM
Doesn't look factory. Almost looks like a coupler was used between the filter and the fuel line. Lefty loosey, right tightly. Wrench on filter, wrench on middle hex.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 04-06-2024, 10:36 AM
You should use a flare wrench on the bottom fitting while holding the one above it. Reverse flare fitting kinda like brakelines
Old 04-06-2024, 10:38 AM
911SC '82
It is factory actually. There is no coupler this is how the Mahale fuel filter is. It does end with a female nut
Old 04-06-2024, 10:43 AM
911SC '82
Ok i removed the “coupler” but as you can see
The brand new filter on the right has is already installed.
Old 04-06-2024, 10:53 AM
911SC '82
Ok i think i reinstalled everything. Anything i need to che k before anything can explode?
Old 04-06-2024, 11:52 AM
911SC '82
Also by any chance anyone know what is this? With yellow collar? I think is breaking apart…
Btw this is a 911sc 1982
Old 04-06-2024, 11:56 AM
Still here
pmax's Avatar
Your "brand new" filter is dated 2021.
O2 sensor connector, it will fall apart completely eventually.
Old 04-06-2024, 12:20 PM
proporsche's Avatar
[QUOTE=pmax;12227651]Your "brand new" filter is dated 2021.
yup, almost 2020..i`d get new..not old stock filter....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-06-2024, 12:28 PM
911SC '82
This was ordered on pelican guys
Old 04-06-2024, 12:39 PM
911SC '82
Ok car starts well. I have a tiny wetness on top of the filter. Im not sure how much do I have to tighten it
Suggestion?
Old 04-06-2024, 12:40 PM
911SC '82
[QUOTE=proporsche;12227656]
Ivan
That sounds like a nerdy useless comment. filters don't have short shelf-life.
there is nothing inside a filter other than an accordion filter... it;s not rocket science
you just wasted my time even to check your answer
Old 04-06-2024, 12:52 PM
kevingross's Avatar
You just need a couple of wrenches: one on the coupler to counterhold, another on the fitting at the end of the rigid pipe. Preferably crow foot wrenches. Go buy a set, they are essentials. Hope this helps.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 04-06-2024, 01:00 PM
82 911 SC - Ancora Imparo
The component with the yellow collar is the cruise control servo.
Ethan
1982 911 SC - Wine Red Metallic Coupe
Old 04-08-2024, 11:51 AM
Targa_PB_78_SC
mike sampsel's Avatar
Suggestion?
Just keep snugging it up until there is no wetness (fuel pump running and test with a dry paper towel as you tighten). With short hand wrenches it is hard to get it too tight, unless you are a gorilla. Use the squeeze the two wrenches together method to snug it up.
BareRearedRookie
Old 04-08-2024, 03:12 PM
PCA Member since 1988
I've pulled off a few of those adaptors from old fuel filters. They are put on with Locktite or similar. Really tough to get off. But the new filter I used came with a new adaptor already attached.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-08-2024, 03:19 PM
911SC '82
ok, so far so good... not wet parts. all seems dry after about 50 miles driven after replacing fuel filter/accumulator.
will it last? I'm a bit paranoid and thinking I may need to replace also the S-shape metal pipes...ugh
Old 04-10-2024, 10:43 AM
