74 Carrera fuel pump location
Hi everyone, today I wanted to R&R the fuel pump on my 74 911 Carrera Targa but lo and behold it is not behind the gas tank where it’s supposed to be!!?
Any guidance will be appreciated very much! Thanks Last edited by Fred FT; 06-05-2024 at 05:39 PM.. |
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 06-05-2024 at 05:45 PM.. |
FWIW, you have two choices for replacement:
1-Factory Style for mucho dollars (https://www.pelicanparts.com/More_Info/91160811056.htm?pn=911-608-110-56-OEM&bc=c&SVSVSI=9284); or 2-Universal pump which will require you to modify the power and plumbing (https://www.pelicanparts.com/More_Info/91160811056.htm?pn=911-608-110-56-M14&bc=c&SVSVSI=9284).
Registered Minimalist
You can also replace all the fuel lines and convert to a front mounted pump. It's a two week home mechanic DIY job but totally doable. At the very least, replace the short lines at the front and back as they will be completely rotted by now.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
