Safe storage of Carrera 3.2 fuel injectors?
My intake manifold will likely be apart for at least another few months.
Should I get some protective caps to cover the top and bottom of the fuel injectors?
Old 04-08-2024, 02:52 PM
PCA Member since 1988
Nah, just be careful with them.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-08-2024, 03:17 PM
Since they are going to be ot of service for a while, why not have them cleaned and flow tested to be sure they are in great shape when they go back in? I am lucky to have a boat place local that has an injector cleaner. He has saved me a couple of times.
Old 04-08-2024, 04:46 PM
That's a good suggestion.
Old 04-08-2024, 10:11 PM
That was my plan, until I watched the video from Franny below where the injectors came back with a recommendation to install immediately. Now I'm thinking I'll wait to send them in for rebuild until shortly before I'm ready to reinstall the engine.
https://www.youtube.com/watch?v=FeU-dYI9-fs
Old 04-09-2024, 08:34 AM
I have heard that fuel pumps should be plugged when stored so seals don't dry out. Is this something to consider for injectors? Saran wrap them?
Old 04-09-2024, 03:21 PM
They don't have rubber seals, but it's a good idea to plug or bag them to keep dirt out.
Old 04-09-2024, 05:53 PM
Cairo94507's Avatar
I agree with Fanny; I had the injectors serviced on my 3.2 while we were building the engine. 8 months later we installed them and...no good due to sitting- despite being wrapped in the bags in which they were returned. Ended up replacing them with new injectors.
'71 914-6 #0372
'17 Macan GTS
Old 04-10-2024, 06:39 AM
Still here
pmax's Avatar
I assume you returned it the shop for warranty service.
Which rebuilder was this ? If all 6 went bad after only 8 months, not sure you should use their service again.
Old 04-10-2024, 12:54 PM
