Dealer scratched new Fuchfelge wheel..what are my options?
Brought my new Fuchfelge wheels to Porsche to get my tires mounted and balanced. Theory being that they have lots of experience with high end wheels and tires...and so ought to do a good job.
Well, they scratched the anodize off near a valve stem and now the question is how to repair it. The ideas include re-anodizing with a local provider, but I am somewhat nervous about the long term durability of a redo. Porsche is committed to make it "right" but not sure if it is possible. Replacement of the wheel is basically not on as Fuchs only makes a few of that colour/size/offset and even if available, they are certainly going to be stupidly high priced. Anyone out there have any advice or comforting words before I go off and sulk in a corner for the rest of the week? D. |
Doubtful. I'd be willing to bet the dealer would want to be made whole, and a repray isn't likely to cut it. |
Not your business. You gave them perfect wheels, they give you perfect wheels back. I take it Porsche have a rather good relation with Fuchsfelge
Dealership buys you a new wheel. Wheel will have to be stripped of paint, then stripped anodizing, then anodized to the exact same sheenas original (that won't happen), and then repainted.
So dealership buys you a new wheel. A similar thing happened to me years ago with dismounting tires from a set of Harvey's RSR finish deep 6s and welded 7s. Went to the high end shop in town, explained how they were made, how long it took to have them made, explained that I had sold the wheels so they have to be perfect. Be extra careful in every step. Go to pick them up, one is scratched, all are on the dirty/sandy shop floor, backs are scuffed from poor handling. They ended up giving me $1K which I gave to the fellow who bought them.
Tru6 Restoration & Design Last edited by Shaun @ Tru6; 03-06-2024 at 06:59 AM.. |
"Making it right" means they buy you a new wheel. Am confident you'll have to apply some pressure to make that happen. (Best thing for them is for you to ignore the situation.)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Happened to me last year. All the faces of my refinished fuchs were marred by dirty rubber caps used in mounting and balancing. The shop made good on it and sent them back to the finisher to be redone, then used the proper cap when they came back. They took care of the cost.
Edit: As far as re-anodizing with a local provider: No. Not unless they're extremely good and do all four wheels. Getting just one re-done will leave you with one wheel that doesn't match the others, no thanks.
1982 911SC Last edited by David Inc.; 03-06-2024 at 07:10 AM.. |
It's a 914 ...
Man, I sure wouldn't want to be in the business of mounting and balancing tires on expensive rims. Seems like a low margin business with huge downside.
What it requires is CARE and attention to detail. I have handled those wheels while doing mockups and always with padding underneath, always with masking tape on parts which may get scratched...they were perfect going in, I am leaning to telling them to contact Fuchs and let's get another one. I worry about quality of re-anodizing and also the matching process.....so let's see what they come up with. D. |
Just chiming in to let others know to check your wheels after tire mounting. Both times in the last few years my wheels have come back scratched and half were near the valve stem (same as OP). Talking to other owners around here, tire mounting and the lack of care going into it, seems to be on the decline - as it's actually come up a few times... I took it for granted with my old shop and never had issues. They closed down and now I have taken two sets to two different installers. "High end wheels" being a specialty at one in particular. My car is a near daily driver so.......not hyper focused on something I have been able to partially correct at home, but very disappointing none the less. If I had new rims-yes, I would be upset. Best of luck to you and the outcome. Erik
1986 911 Coupe 1986 911 Targa |
It's a 914 ...
I've had a couple bad experiences having racetires mounted. Enough so that I've acquired equipment to do it myself (gulp). We'll see how that goes. At least if I damage something, it'll be on me.
OK, dealer says they will have the wheel completely stripped, the black parts repainted and the whole thing anodized at a regional shop...that they apparently have used before.
I raised the concerns about whether it would match and such and to make a long story short, they believe it will match but remain "committed to making it right" including a redo-do if needed. We shall see, about 2 weeks to do the whole shebang... D. |
If it's not stripped with chromic acid, it will require a lot of surface prep to match the anodized tone. Even with chromic, surface prep will still be required.
Good luck.
Tru6 Restoration & Design |
Can you lend them another wheel so they can try to match it.
We shall see....couple of weeks apparently.... D. |
Good luck, tot ziens for now.
Still here
Ah, good thought....too late I fear....I should have asked....I think the wheels are at the wheel shop as we speak..
D. |
You might be able to send it back to Fuchfelge, or their US distributor, and have them refinish it correctly.
As a previous post indicated, this is high-risk for relatively low return for dealers. It appears you didn't buy the tires from them, by your post. If that's the case I'm surprised they'd even agree to do mount your tires.
2018 Porsche 911 GT3 manual 1984 Porsche 911 Carrera Targa 2021 Porsche Macan GTS 2018 BMW R1200GS Adventure Rallye 2020 Ducati Scrambler 1100 Sport Pro Last edited by josephvman; 03-07-2024 at 05:47 PM.. |
(man/dude)
I have nightmares about having tires mounted to the 16 x 7's and 9's (in unobtanium silver/black!) Fuchsfelges that I have for the latest project.
I'm considering having them wrapped first with a heavy 3M vinyl. Anyone else tried this?
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
I think these wheels are short runs for them, and I am pretty sure they have very limited spares. Worst case....we will see how things turn out. D. |
