-   -   replacing door seals on 83 sc (http://forums.pelicanparts.com/porsche-911-technical-forum/1160220-replacing-door-seals-83-sc.html)
hughc 04-11-2024 12:55 PM
Is there something special I should know about replacing the door seals on my sc?
Will they just pull out and push in? Is there glue involved.?
Thanks,
hughc
ahh911 04-11-2024 01:38 PM
Hughc,
I simply pulled the old ones out, did a average effort of removal of adhesive from the channel.
Replaced with a 20$ uro seal, works great.
No glue for me, if it ever comes out of the channel I'll glue it in, but for now don't see any need.
Phil
hughc 04-11-2024 03:12 PM
Originally Posted by ahh911 (Post 12230486)
Hughc,
Phil
Thanks Phil, sounds simple enough.
I'll try it your way.
Cheers
PeteKz 04-12-2024 01:08 AM
I didn't use glue either, they have stayed in the channels. Easier to get them out "next time"!
Snwmble 04-12-2024 06:51 AM
I used a little double stick tape in the area i felt were going to lift
AG81 04-12-2024 07:55 AM
I just did my 72 and used Porsche seal. I tried two other brands and the door will not shut correctly, even after trying to adjust it. Maybe it's a long hood thing. As far as adhesive I needed a bit in the floor corners.... the rest stayed put and needed a bit of help due to new paint. for adhesive I used the yellow 3M 08001 Weatherstrip and Gasket Adhesive sparingly.
