			 911SC '82
				How to use a tension gauge like this for Altenrator/AC belts
			I bought this on amazon, but I realized i don't understand how to use it and what is the correct measurement I should read.
				I know ballpark the belt should move only between 1/2 to 1/4 inch no? but no idea how this tool works
			Push on the belt with your finger, if it moves about half an inch you're good. If it squeaks while running it's too loose, if it whines a bunch it's probably too tight.
			Neither belt on the 911 is super sensitive to tension.
	1982 911SC  |
			 911SC '82
			For another way to test, the fan belt should be just about tight enough such that you can turn the engine over by turning the fan (with a little squeeze on the belt to help get through the compression strokes).
	1982 911SC  |
			That tool was intended for flat toothed belts and maybe serpentine belts.
			 911SC '82
			 Still here
			The official method is to use your thumb.
