LinkBack | Thread Tools | Rate Thread |
911SC '82
Do you need to do any adjustment in engine after replacing fuel pump?
I'm trying to isolate different problem i have when starting the car.
I replaced my old noisy/whining fuel pump two days ago. it did work great the same afternoon. good acceleration, idle at 1,000 rpm all day when in traffic, tested on all gears, and no hesitation whatsoever. but then the next day I had this issue of rough idle when starting the car. So rough sometimes that it dies after touching the gas pedal (air bubble in the fuel lines??). Never had this before. Actually, I used to have the opposite of the car going to 2,000 rpm back and forth until it reached a stable rpm. so my first thought was the culprit must be the fuel pump. maybe the hoses/clamps? electric wires connectors? so my questions are:
thanks! NOTE: battery is almost new, alternator rebuilt. starter, maybe old stock but starts. |
PCA Member since 1988
The pump is a plug and play replacement. No CIS adjustments necessary.
An early pump failure is unlikely, but possible, especially if it's made in China. I haven't seen a pump be bad at the start and then get better, or warm up.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Pete, while we have you here... What are your thoughts. I replaced my fuel pump on my ROW SC with the correct one for the car (can't remember the model) and the car ran very well like it always does. The old fuel pump was actually a BMW model according to the place that sold me the new one. Now the car seems to be chewing through the gas a bit too quickly. I've got no idea of actual miles per gallon, but it used to be very fuel efficient and not so much now. Umm, any ideas - thanks.
https://forums.pelicanparts.com/porsche-911-technical-forum/1159036-occasionally-slow-start-after-city-drive-3.html#post12232751 Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Senior Member
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Banned
So you just have the issue during startup, and it clears out when everything's warm? The previous issue with idle surging wasn't good either. Sure everything else is healthy? Good mix? No vacuum leaks?
911SC '82
yes, it happens ONLY at startup and ONLY when hot.
yesterday for instance I started the car and it was all good. (4-5 cranks and good RPM right away, no hesitation, no shaking, no sputtering) it seems that the issue is only when the car is really hot (oil temp slightly above the second white mark but not in red of course). this happens when I drive in the city (I'm in NY) and if I drive for an hour of stop-and-go at 25mph it gets hot fast. this is when the hot start problem happens. I think replacing the filter/pump/accumulator has just made it worse because MAYBE the PO setup the engine/warm/cold valves as a bandaid. i definitely need to check for vacuums etc. but when the car starts cold it drives flawlessly and great acceleration when I press gas. |
911SC '82
The tank filter was replaced the same day. fuel filter and new accumulator 1 week old.
I think the pump is URO or Danks. but that is a pointless factor, to be honest, considering is only a day old, if it was faulty I would have discovered right away. |
Banned
Hot start issues are common, I'd suggest doing a search on them you'll probably find others who dealt with the same problem. Not a fuel pump problem.
Thanks Thomas. That makes sense. Much appreciated.
CIS Troubleshooting………….
Without knowing your fuel pressures (CCP, WCP, SP, & RP) you are just working blind and guessing. Do you have access to a set of pressure gauge? If it takes multiple attempts to get your motor to start every time you drive your car, something is wrong with your CIS. And the problem will not go away. You need to test and identify the culprit/s.
Tony |
Lash
The first pump was made in Mexico or south America.
Lash 1963 356 T-6 Normal Coupe 1972 911 T Coupe ..... Sold 1972 911 S Targa ...... Sold 1980 911 SC Coupe Weissach |
Bill, I think Thomas covered your questions, so let me add a bit more.
IF the pump meets the delivery test, then functionally it does not matter what pump you install. If it passes the delivery test, then it delivers sufficient pressure and volume to the CIS. It is still a good idea to check the pressures when you replace a CIS component, as Thomas suggested, just in case you whacked or pulled wires while you were in there.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 04-16-2024 at 11:19 PM.. |
Will do, thanks Pete.
Bill, if you ever wanted to venture as far north as Hawkes Bay I would be prepared to check your system over.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Thanks Alan. I have relatives in Poukawa I have been promising to visit for years. So I may take you up on the offer. Plus 6,000rpm in top gear along the Takapau is always fun.
PM me if/when you have a plan. I am off o/seas end of May for a bit.
Regards Alan
Will do - thanks.
