FPR to FD Body Torque?
I know I have read it somewhere but been searching my Bentley and the forum and cannot find it.
Looking for the torque number for the 16mm nut FPR to fuel distributor body. ![]() Thanks |
PCA Member since 1988
There may be an obscure torque spec for that somewhere, but I haven't seen it. Maybe Tony has it. On copper washers, I tighten them enough that they don't leak, and just a touch more.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I have never torqued it. I do what PeteKz does. Not had an issue. If there was a number, it would be low, I don't crank on it til my arm hurts. <15 ftlb, prob less than 10.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
1.3 to 1.5 mkp
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
1.4 mkp x 7.233 lb/ft = about 10.1 lb/ft or 121 inch pounds.
I have never torqued it either but troubleshooting a small issue and want to eliminate as many things as possible. Thanks |
Clarification……….
That seems to be from the 004. The 006 came in around '75.
![]() Modifications April 1976 Maybe 006, 017 ![]()
Ed 1973.5 T Last edited by E Sully; 04-26-2024 at 08:11 AM.. |
Completely Two Different Parts…………
Please be aware that item #1 (plug) as posted by Dp is NOT the same nor close to the Primary Pressure Valve with push valve found in SC fuel distributors (-031/-077). They are not comparable by any means. We are comparing apples to oranges.
Tony |
Never said they where the same. It’s safe to assume like materials with crush washer screwing into fuel distributor would have similar torque values.
This is all that I could find regarding Torque.
![]() In case anyone is interested, this is a partial list of Bosch's Service kit for fuel distributors. ![]()
Ed 1973.5 T |
![]() Thanks FYI mine was way too tight. I had to get a longer handled ratchet to break it lose. 10-11 ft lbs is not much, but its not leaking so all good. |
