911SC '82
Question is there a battery that has poles on the other side?
is there a battery for 911SC that has poles on the other side?
my poles are close to the body, with the positive pole very close, also they both hard to access because of the lack of clearance around them.
i wonder if there a brand that has them on the other side, much easier to disconnect in case of maintenance work
Old 04-22-2024, 05:18 PM
HarryD's Avatar
Optima offers a battery with the poles reversed.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-22-2024, 05:47 PM
Ctopher's Avatar
Depends on the manufacturer but some have an R which reversers the poles. I bought an odyssey PC925L which have the poles reversed so they sit inward toward the tank.
CTopher
Old 04-22-2024, 06:41 PM
911SC '82
CTopher
"they have an R"? What is it? a toggle?
Old 04-22-2024, 07:19 PM
HarryD's Avatar
From the Optima Web Site. Note 34 and 34R.
Harry
2020 MB E350 4Matic
Old 04-22-2024, 09:02 PM
Alan L's Avatar
They come in all variations - depending on manufacturer and the range they offer. Not all vehicles are the same. + on one side, - other , +/- same side, +/- opp side, + one side, - other and vice versa.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-23-2024, 01:21 AM
francesconyc -- suspect your car has a "boat anchor"-sized group 49 battery. Recommend you get a slightly shorter group 48 battery, which will power your car's electricals just fine and be a lot easier to maneuver in (and will lock in place using existing fasteners). Also, get one that uses AGM technology, which are MUCH less prone to leaking/boiling over when your voltage regulator fails. As for terminal orientation, if you remove the connection from the negative terminal first, you don't need to worry about the positive terminal's proximity to the body, as disconnecting the battery's negative terminal causes the positive terminal to no longer be "hot"
Old 04-23-2024, 06:22 AM
911SC '82
sure, and is not that im working on the car everyday... but it just drves me crazy that has to be so badly designed
I heard Odissey PC925L is recommended also on Rennline, but what kind of terminal have those??
Old 04-23-2024, 06:59 AM
the PC925L is a much smaller battery than the stock group 48 or 49 and has less than 1/2 the CCA of a group 48. While it will start a 911 just fine (and be easier to work with), the lower capacity of a PC925L provides less reserve power for unforeseen situations (i.e. while a normal battery can power an accidentally-left-on dome light overnight w/o issue, the same load could completely discharge a PC925L in the same timeframe, ditto parasitic drains, etc.). Also, securing the PC925L requires the purchase/fabrication of an adaptor, as it's too smalll to be secured by the factory battery mounting system.
Old 04-23-2024, 07:08 AM
911SC '82
Ok I just ordered the Odyssey PC925L with their terminal, not cheap but I read a lot of good things, AGM, higher power... sounds good. i just hate my big fat Duracell so heavy barely fits in there. I can't believe the PO was so sloppy, they even placed a piece of cardboard to protect the positive pole... ugh
Old 04-23-2024, 07:12 AM
911SC '82
sure, but I always have my NOCO battery-jumpstart in my trunk if by accident I would keep the lights on overnight or so
Old 04-23-2024, 07:13 AM
911SC '82
I was sold by this video
https://www.youtube.com/watch?v=QHoBWZmd614
Old 04-23-2024, 07:18 AM
francesconyc -- which mounting kit are you going with -- here's a thread with a few options https://forums.pelicanparts.com/porsche-911-technical-forum/1052409-pics-odyssey-pc925-rennline-mount-sc-3-2-a.html
Old 04-23-2024, 07:20 AM
911SC '82
fantastic, thanks!!
Old 04-23-2024, 07:23 AM
PCA Member since 1988
Jeez, talk about pushing the BS to sell a battery! "Increased ignition output delivers smoother superior performance."
No it doesn't. Unless the charging system is bad, the charge in the battery has nothing to do with it. After start, the battery just sits there and sucks up 'trons from the charging system, and does not put any out. Same BS flag on the other claims.
I am not knocking the battery--it's sufficient, is smaller, and weighs less than most. But the other claims are outright false.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-23-2024, 04:33 PM
Originally Posted by petekz View Post
jeez, talk about pushing the bs to sell a battery! "increased ignition output delivers smoother superior performance."
no it doesn't. Unless the charging system is bad, the charge in the battery has nothing to do with it. After start, the battery just sits there and sucks up 'trons from the charging system, and does not put any out. Same bs flag on the other claims.
+1
Old 04-24-2024, 02:26 AM
