72 Blinker blues
The blinkers on my car work fine with engine off. If I start it they still work. But once I blipp the gas the fuse blows and they stop working.
72 911 82 911 70 GTO ![]() 97 GT Ragtop 74/76 Jeep cj's |
Well, that's odd because there isn't anything attached to the throttle, electrical wise, on a 72. Have you checked around the cluster for a loose wire from the stop light switch?
72 911 Although it is done at the moment, it will never be finished. |
Check charging voltage for overcharge.
