mordecaibrown's Avatar
Small Oil leak
I have a very small oil leak on my 1977 Porsche 911s Targa. Any recommendation on how to fix this.
Thanks,
Sam
Old 04-30-2024, 01:14 PM
Check the chain cover nuts to see if they may have worked loose, or never properly torqued down. Just snug all them up, clean the area well and check after a couple days. I don’t have the torque spec.
Had same issue probably vibrated loose. So far no seepage.
Worse case is new gasket(s).
Old 04-30-2024, 02:01 PM
Ok Thanks!1
Sam
Old 04-30-2024, 02:54 PM
proporsche's Avatar
you can try to secure the nut but most likely you will have to replace the chain cover gaskets
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-30-2024, 04:07 PM
Does anyone know the torque specs? seen a previous post are they correct?
https://forums.pelicanparts.com/porsche-911-technical-forum/83090-what-torques-use-chain-housing.html
Old 05-01-2024, 07:20 AM
