gearbox shifter query
So my SC gearbox works well - no issues over the last 20 yrs. Even after 1-200 miles without a clutch once. But it does have a quirk which I don't understand.
If I coast to a stop in 5th, I cannot get it out of gear. So I work around that by downshifting to another gear. Then it is fine at a stop, can get to neutral no problem. But if I arrive at a red light for example, in 5th, I would be stuck in 5th. If I tried to deselect by force it feels like it would break a selector fork. I have managed to get it back to neutral by rocking the load on the box with some revs and the clutch. Pick the point when the load just shifts from load-no load. What causes this issue? Not about to tear the box apart, it is fine. But would like to understand what is going on. Thanks Alan |
very strange to arrive to stop sign in 5th if you ask me;-)
i`d just say, don`t do it... Ivan |
My first thought is to check or just replace the shifter bushings and then readjust the shift coupler. There are plenty of videos on how to do this, just search.
Be sure to replace all four bushings; two in the coupler itself, one on the shift rod and one that connects the shift lever to the shift rod. Our host sells a kit with all the bushings needed: https://www.pelicanparts.com/More_Info/PELBUSHKIT1N.htm?pn=PEL-BUSHKIT1N&bc=c&SVSVSI=0581 This is a relatively easy Saturday afternoon DIY. |
Yeah I guess that is a possibility. Easy to do. Thx
"very strange to arrive to stop sign in 5th if you ask me;-) i`d just say, don`t do it..." Just coasting - clutch in, knowing I am going to a full stop. Why go thru needless downshifts? What I tend to do then - knowing the issue, is flick to neutral and just coast. Alan |
I assume you made damn sure the clutch is fully disengaging.
Inherent in the design of any standard-shift car, is an expected, down shift - a few gears - if you are anticipating a stop, it's much safer and healthier for the mechanics of the clutch & transmission than what you are practicing. The fact you can't shift out of fifth, is proof that the Porsche engineers are mad at you. Your car has a soul you know, don't hurt its feelings.
Yes - I guess they are punishing me. One downshift is enough to rectify it. So I don't coast to a stop in 5th - for many yrs. because I know what happens.
The odd thing is if I do same in say 2-3-or 4, no issue. Just 5th. Yes Pete, clutch is good. The gearbox and clutch are working beautifully (fitted complete new clutch asseembly 2-3 yrs ago)- can't complain. Just wondering what the issue may be - other than some angry guys in Stuttgart. I think the F1 engines have telemetry that tells the builder on the other side of the world every time is is fired up. Maybe my SC is ahead of them. Some day, sometime, I may end up pulling the gbox down. If so, if there was something in there that was not right, I would prefer to be able to address it. Regards Alan |
i wonder in what speed you are at in 5th when you are cruising???
Ivan |
Open hwy - say 100kmph (about 60 mph).
the typical situation would be like a country road, approaching a stop sign. 100m out, start slowing, braking, knowing you have to come to a full stop. Not a lot to gain by downshifting thru 4 or 5 gears. For what reason? Coast to a stop and look for neutral. If your were in 5th you would be stuck in 5th. Not sure if it is a general problem, or an issue in the g/box. A first world problem, for sure. Just wondering if there is a problem in the gbox that could be rectified at some later time - something not quite right. Alan |
kinda slow for the 5th gear i would say 100m to go and still in 5th??.....basically shift into 4th and problem solved....
Ivan |
That's definitely a weird problem.
If you shut the engine off does it does it allow you to move from 5th to N? If you were already stopped and in N, then put it into 5th would it immediately stick, or could you just move back to N? is it associated with coasting to a stop in 5th, or just being stationary in 5th? |
let`s see what Matt Monson will say....
Ivan |
if the adjusting nut (22mm I believe) on the front of the shift tower is too tight, you can get stuck in 5th due to the lockout mechanism. Ask me how I know...easy to check it.
If I am coasting to a stop, in 5th I have to get it out of 5th before stopping, or it will be stuck there. Sounds like The torch has supplied an answer - thx. Just didn't know where to look. Where do I find that nut? Alan |
Some of our roads are now reduced to 80kph (50mph). Why, because people keep crashing. So instead of improving the roads, or making people drive better, it is better we all go slower. Luckily I get to drive my 930 at WOT on a track, so I am happy cruising in my lazy SC. The torque makes for very easy driving, and I am still allowed to attack the corners at a speed the car will handle :-) I have had 2 clutch cable failures (clevis pin/fork). No fun. Have modified that bit now. So I just don't do needless downshifts when cruising to a stop. But yes - down 1 gear and problem solved. But my original Q was - what would cause the issue. Looks like The torch has the answer - which I am glad to find. Regards Alan |
Before you try to pull the gear lever out of the 5th gear, push it more into the 5th gear lane. Then try to pull it into neutral lane. Does this work?
Thomas |
Thanks Thomas - but I am not really looking for a work-around - I just avoid the issue. Was really looking for the reason it behaved like that.
Regards Alan |
Thomas |
Ivan |
I am not sure where it is Ivan. I did post a query for Thetorch - but not heard yet.
I am guessing it is external near the shift stick, rather than internal in the box? Regards Alan |
I cant see it in this pic, so thinking internal?
Alan http://forums.pelicanparts.com/uploa...1714520511.jpg |
here you have it, the front of the shift tower
https://i.ebayimg.com/images/g/crIAAOSwMb9ivI4G/s-l500.jpg https://i.ebayimg.com/images/g/qoQAAOSw-xBivI4L/s-l1600.jpg |
OK, so before I go ripping into this adjustment I am trying to understand what is going on here. Did a lot of searching and have found no reference to adjusting this bit - ie how to set it correctly.
What I did find is this - posted by JW. This seems to nail the problem, and seems to fit with the above post by Schilisco (Thomas - I may have misunderstood you). "if the stick is not all the way over and up into 5th, the little flipper that keeps you from shifting into reverse and allows you to go 5th to 4th properly, can actually hang up and jamb the stick from coming out of 5th. the stick needs to completely clear the flipper into 5th." Is this adjustment related to the above description? I also found several references where as Ivan stated - make sure you shift out of 5th above 60mph. It seems not uncommon, but a weird characteristic. Alan |
last time if i remember correctly, to play with the 2, was for the stick to be too loose..side to side...
Ivan |
What I did find later was that this adjustment was added post'77. My wsm goes to '85/86 and does not mention this.
But I did find a line in a thread that said it was an adjustment for the shifter 'basket' and that it was to be tightened so no play. Just not quite clear what I am doing if I tweek this. Flying blind - since I have not had to pull the linkage or gbox apart on this car, my wsm doesn't cover this, and all is good, except.. I did find a thread with another SC with exact same issue. But like many threads, it was like reading a gripping novel, with the last page missing. Regards Alan |
| All times are GMT -8. The time now is 04:30 PM. |
